Thanks for all the responses thus far, folks. I'm a little surprised there weren't more, as I'm sure we have a lot more folks here shooting older gear, but maybe they're just busy taking photos (and that can only be a good thing!
I bought my first proper digital camera - a 2MP Olympus C-120 "compact" - back in 2002 or 2003, I think. Since then I've owned numerous compact, bridge, DSLR and mirrorless cameras. I still own quite a few of the older ones, though I only occasionally use any of them, mostly for nostalgia
The "vintage" digital cameras I shoot regularly are those I've acquired in recent years. A little background...
Having begun my Pentax journey with my now-sadly-gone K-7, I next bought a K-5, then a K-3 and K-3II (all three of which I still own and use, especially the K-3). But around three years ago I noticed that quite a few members were continuing to shoot much earlier CCD sensor bodies, and getting results that I found very appealing. That prompted me to acquire one out of curiosity, and so began my interest in shooting older digital cameras...
Samsung GX-10:
In October 2016, I bought what I believed (and still believe) to have been a shop demo Samsung GX-10 DSLR (almost identical to the Pentax K10D). It was sold to me as new / old stock at a very reasonable price, and had a shutter count of just 197
After using it for a little while, I fell in love with it. It's built like a tank, the controls are simple, it does all of the core things I want from a DSLR, yet nothing complicated or advanced, and it's very simple and logical to operate. But the highlight is its 10MP CCD APS-C sensor (plus whatever internal processing takes place), which records images in a way I find very hard to describe. It's just "different" compared to my modern CMOS sensor cameras, in a way that I like - certainly when using darktable, RawTherapee or Lightroom. The raw files, which can be saved as DNG or PEF, respond really well to post-processing. There's enough detail for my requirements, too, even with some cropping. In fact, the pixel density is almost identical to the non-Pentax 24MP "full frame" gear I own, so the level of detail is quite familiar. Dynamic range and high ISO performance both lag behind modern gear, of course - especially high ISO. For high dynamic range scenes, I can take two or three bracketed shots and combine them in post-processing (which is what I'd do with my K-3 anyway). I find I can shoot ISO 100 - 400 without any concern, and 800 at a push in situations that require it.
Unless I really need my K-3, I find myself picking up the GX-10 more often than not. I like it so much, I bought a second one - and almost added a third, but (sadly) that fell through. I guess that demonstrates the high regard in which I hold this camera. I also managed to acquire a resonably priced and quite rare SBG-D1V battery grip, which is shaped slightly differently to the K10D battery grip, to accomodate the Samsung body. It increases the already-excellent battery life for a shoot, and makes portrait orientation photography even more pleasurable - but also adds to the weight and bulk of an already-quite-heavy and chunky camera.
One limitation I find frustrating with the GX-10 (K10D is the same) is the inability to store AF fine adjustment offsets for various lenses. This can only be set as a global adjustment via the DEBUG menu (which Samsung and Pentax never intended an owner to do). So, I don't change lenses much when I'm using my GX-10. Typically, I pair the GX-10 with my Tamron AF 28-75mm f/2.8 XR Di LD (originally released in 2003
), which - for my use cases - is an excellent general purpose lens. But, I leave the DEBUG mode files on my SD card, and carry a list of adjustments for all lenses I own in case I should want to change to something else...
Pentax *ist DL:
Some months later, in 2017, I saw a local Gumtree listing for a Pentax *ist DL and a couple of lenses, one of which was the FA 28-105 f/3.2-4.5, priced at about half of what that lens alone can sell for. I bought the lot, primarily for the 28-105 lens, which is competent for its age. But after playing around with the camera, I realised I liked it a lot. Simpler even than the GX-10 / K10D, with rather "leisurely" AF, no image stabilisation and a 6MP sensor that shows its limitations in landscape shooting where foliage and other fine details are concerned... but it's still capable of taking really nice images when used to its strengths. My camera is in good condition, but the control wheel tends to skip or jump settings. That led me to purchase, a little while later, a...
Samsung GX-1L:
Essentially a re-badged *ist DL2 with user interface differences, this is a lovely little camera. Same general limitations as the *ist DL above, but since it's in 100% working order, there's no frustration. Like the GX-10, it has no lens-specific AF fine adjustment, so I've used the DEBUG mode (accessible through simple button presses at startup) to set a general adjustment that works well with most of my lenses. The lower pixel desnity of the 6MP sensor is a bit more forgiving, so swapping lenses is a little easier. Even so, more often than not I use it with the "plastic fantastic" DA35 f/2.4, which makes for a great, small, lightweight combo.
I'd be the first to admit that my older gear is more limited than my K-5, K-3 and K-3II. There are times when the newer cameras are preferable, even essential - for example, lower-ambient-light hand-held shooting, or situations where the maximum reach of my lenses means I'll need to crop significantly to get the final image. But for most other typical situations, I continue to be delighted with these older cameras and what they can achieve with a little common sense, care, thought and technique.
I've said it before in these forums... If I had to pick just one combo to shoot with, it would be the GX-10 and Tamron 28-85 f/2.8. I really enjoy using all of my gear, but for my limited (though still quite wide-ranging) use-cases, I could happily make do with this simple, inexpensive, "outdated" kit. It's capable of beautiful results if you work with its limitations, using a little common sense and ingenuity.
You good folks might be interested and entertained by
this post from @Snapppy - one of our members who recently tried out an old 6MP *ist DL and produced a great little video about his experience
