Originally posted by Cerebum My ultimate aim is to get it right in camera and minimise the amount I need to do in post.
Good luck on "getting it right", in-camera. There may be some satisfaction in doing the work, but at best, all one gets is a reasonable set of correction factors (four numbers) that will form a good base for color adjustment in PP, assuming that one is shooting DNG or PEF. If shooting JPEG, "getting it right" makes a lot more sense due to the adjustment being baked into the image with little recourse for adjustment later.
There is a misconception that WB has something to do with sensor spectral sensitivity when the truth is that the sensor records the same voltages regardless of WB settings. WB adjustment is always applied as part of PP. Doing WB manually to "get it right" only allows one to arbitrarily assign WB as sun, shade, cloudy, etc. or enter a °K value or use the camera as a colorimeter to read a gray card estimate of the spectral composition of light striking the subject. In each case, one is saving a setting for future reference when processing the RAW and where "getting it right" may well wash the "gold" out of the "golden hour" and the "blue" out of the "blue hour" and the life out of a flame.
(...just thinking that auto-WB does a pretty good job of not taking the correction too far...)
