My biggest problem with most available remote cables is that you have a half-press to focus and full press to release the shutter using the same button. This means you have to go thru the focus part to get to the shutter. My mouse concept has 2 buttons, one for focus, and one for shutter. I can focus once, then shoot bunches of shots without disabling or changing the focus.
I got the pinout from
HERE. Same pinout as the Canon remote.
I tore it apart and found the two microswitches associated with the mouse buttons, cut the circuit board traces connecting to them, and soldered my cord with a 3.5mm stereo plug to them. Voilà! A two button remote.
If you are a slight bit competent at soldering, it's super easy and cheap.
