Show Printable Version 11 Likes Search this Thread
12-05-2019, 10:17 AM - 1 Like   #16
Not a Number's Avatar
I'd say 85% of my shots are with my 105mm f2.8 Lester Dine (Kiron) macro.
12-05-2019, 10:21 AM - 1 Like   #17
I use my DA21mm more than anything else.
SMC Pentax-DA 21mm F3.2 Limited | Flickr
12-05-2019, 10:38 AM   #18
reh321's Avatar
QuoteOriginally posted by ChristianRock Quote
This isn't about a particular lens... this is about what is the focal length you use the most - and your favorite as well if it's actually different from what you end up using he most (like a portrait photographer might use short tele the most, but really loves a 35mm/FFEq the most).
For me it's around 50mm on APS-C on both... I end up using it the most. Even when I have my DA 16-45 on, I use it a lot on 45mm which is close enough. So I guess that's around 75mm in terms of full frame.
I thought of this thread when I went out yesterday to take pictures during my lunch walk with a 24mm lens on my K10D and TWO 50mm lenses on my jacket pockets... (one a f1.4, and the other an f4 Macro...)
30mm is my 2nd most used focal length (was 35mm before I got the Sigma, that's also close enough as well). Again, on APS-C.
What about your?
Honestly, I do not have a “favorite focal length” . Since I got into AF, I have selected my perspective and then zoomed to get my framing.
12-05-2019, 10:45 AM - 1 Like   #19
Just1MoreDave's Avatar
It's about 35mm on APS-C. Last year I started buying SMC DA Limiteds. Each time a new lens arrived, it was my favorite focal length of all time. So it's not 35mm or nothing, there's more flexibility. Handling features matter to me a lot. I had an SMC Takumar 35/2 that never got used because it was too big. I got an old Vivitar M42 35/2.8 for nothing a few years ago, not even that big, but just couldn't find anything to like about using it so I gave it away. But I have used my FA 35/2 back to back with my newly acquired DA Limited 35/2.8.
12-05-2019, 10:50 AM   #20
Depends... I shoot a lot of kids soccer, and there I'm all over the place from 55 to 300 with the PLM. My most used lens after that is probably the 40mm limited, although I've used the 21mm limited quite a lot since I got it earlier this year. I've also had trips where the 15mm limited was almost glued on the camera.
And I think that if Pentax made a tiny 20-something mm WR LTD lens that would shoot to the top of my list.
12-05-2019, 11:09 AM   #21
Sir Nameless's Avatar
Regarding peaks at the common focal lengths, it's interesting how that happens isn't it?
Very true. The flip side is also true, there are some focal lengths I tend to not use unless I make myself (around 20-30 and 65-90). No clue why. I once went out one day with my zoom set at 24 just to force myself to do what I could with it.
Next thing I want to try as a design exercise is go out and compose with camera position (without looking through the viewfinder), then use my zoom to frame. As a side effect, it would be interesting to see what FLs shake out of that.
12-05-2019, 11:21 AM   #22
bertwert's Avatar
How long have you had it? And were you a wide angle shooter before that?
I think I got it September last year, I like wide angle landscape shots
Part of it is probably how nice the lens is to use.
12-05-2019, 11:22 AM   #23
bertwert's Avatar
QuoteOriginally posted by ThorSanchez Quote
Yep! If only the 21 Ltd was WR, I'd probably not use another lens again...
Took it as my only lens on a trip to Scotland and didn't find it lacking, just worried about lack of WR when out on multi-day ski touring trips through blizzards and such. End up using my 18-55 sometimes just because of WR.
12-05-2019, 11:28 AM   #24
Madaboutpix's Avatar
By far my most used FLs on APS-C, which is the only thing I shoot, turn out to be the 10, 15, 18, 35, 50, 55, and 300mm. Even when using zooms, I seem to gravitate towards those focals. 18mm sees much less use since I no longer use my 18-55mm kit zoom. Likewise, much of what the 55mm zoom settings used to do gets now done with my optically superior DA50 prime.
Actually, I like having options -- extreme, moderate, as well as standard focal lengths -- but when I have no idea of what I will encounter and have to decide what lens to put on the camera, more often than not, I will grab that 50-mil. If I owned a compact-but-awesome 21, like the DA21 Limited, I bet that would see a lot of use too.
12-05-2019, 11:52 AM - 1 Like   #25
ChristianRock's Avatar
QuoteOriginally posted by reh321 Quote
Why don't you surprise yourself and try to find out what the most used focal length has been?
12-05-2019, 11:53 AM   #26
Not traveling much anymore so I would say I probably use the 180mm macro to fool around the house and garden as much as anything else. When I do get a vacation & shoot landscapes it would be 24mm and on the DFA 28-105 the 85-100mm area.
12-05-2019, 11:55 AM   #27
QuoteOriginally posted by Madaboutpix Quote
That's a bit vague isn't it? Are you sure there isn't one or maybe two focal lengths that you just end up using a bit more than the others?
12-05-2019, 12:06 PM   #28
c.a.m's Avatar
I guess I'm a short telephoto kinda guy -- my most frequent focal length is 50 mm on APS-C.
That's not too surprising -- I shoot often with my DA* 50-135, and it's one of my travel lenses.
The next common FLs are 35 mm (DA 35mm Limited), 300 mm (DA* 300) and 21 mm. 43 mm is catching up, though.
- Craig
12-05-2019, 12:09 PM   #29
kiwi_jono's Avatar
My "Favourite" seems to change over time, partially due to spending more time with a new acquisition and partially because I'm shooting a certain type of subject for a period.
However if I averaged it all, I suspect it would fall somewhere around FF 43mm and this is also a focal length I'm using quite a lot at the moment.
12-05-2019, 12:19 PM   #30
Jeff's Avatar
On my K1 it's the DA* 50mm 1.4. If I have my KP then it's the 35mm 2.8 macro (which becomes then almost a 'normal' lens) and on my tiny GX800 it's the Sigma 19mm - also near normal. I really like these FL's as they represent what I see. And of course I also like to use the 43mm 1.9 - as perfect a normal lens as you can get on FF.
50mm, aps-c, length, photography
Focal length = focal length, I know . . . . . . . . . . BUT onlineflyer Pentax SLR Lens Discussion 152 08-19-2022 06:04 PM
My Favorite Focal Length Lens for Shooting Beauty benjikan Photographic Technique 5 09-09-2010 08:59 PM
My Favorite Focal Length for Studio Fashion benjikan Photographic Technique 11 08-11-2010 05:13 PM
How to check most frequently used focal length in flickr and/or photos on harddrive raider Digital Processing, Software, and Printing 10 12-03-2009 12:15 PM
What is your most used Lens/focal length Fl_Gulfer Pentax SLR Lens Discussion 43 02-21-2009 12:36 PM
All times are GMT -7. The time now is 10:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
