01-02-2020, 09:34 AM - 1 Like   #1
steamloco76's Avatar
Clamp on Lens Hood for 35-105 A
I found a quick mounting solution to the no lens hood availability for the SMC Pentax A 35-105/f3.5 zoom. The metal clamp-on style hood for the Tokina AT-X 28-135mm is a perfect direct fit for thePentax lens. I found mine at KEH for $4.80. eBay has a couple every now and then.
I super glued a 12mm extension to my hood, used the outer ring of a 62mm thread collapsible rubber hood fit inside the very end of the Tokina metal hood. Still no vignetting.
IPad Air  Photo
IPad Air  Photo
01-02-2020, 09:35 AM   #2
amateur dirt farmer
pepperberry farm's Avatar
I've used a screw-in metal hood on mine, but looks like a nice solution...
01-02-2020, 09:56 AM   #3
D1N0's Avatar
I am using the Hood for the vivitar Series 1 70-210mm 1:3.5 on it (Kiron version). It's also a clamp on hood.
01-02-2020, 09:56 AM   #4
monochrome's Avatar
I have a Tokina ATX hood that fits directly without mods (as well as the correct OEM rubber hood found on eBay).
01-02-2020, 10:08 AM - 1 Like   #5
My main reason for wanting a clamp-on style hood for the 35-105A? Mine came with a very deep dent in the filter ring. I was able to restore use of the threads by carefully removing the dent with a lens ring vise. The first thread is very hard to catch quickly, so the clamp style hood eliminated the fiddling around.
01-02-2020, 10:11 AM - 1 Like   #6
BigDave's Avatar
I added a 67-72mm step-up ring to mine so I could carry less polarizing filters, added a 72mm cap for the lens and just use a collapsible hood that I can use for a number of lenses. This is a nice option though and seems well thought out.
01-02-2020, 12:16 PM   #7
monochrome's Avatar
QuoteOriginally posted by steamloco76 Quote
Bill: Makes sense. IIRC my Tokina hood is a clamp on. I’ll dig it out. If it is and you want it = yours.
01-02-2020, 01:51 PM   #8
TaoMaas's Avatar
I've got a pretty deep screw-on metal hood on my 35-105mm. Works great on APS-C...not so much on FF, I found out. Now that I've got a K1, I may have to go back to the rubber hood I was using in the film days.
01-09-2020, 10:06 AM   #9
SpottyReputation's Avatar
Can i ask what hood this is? I don't want to pay the $40 or so for the OEM hood... trying to find something a touch nicer than the $6 generic hoods...
---------- Post added 01-09-20 at 11:08 AM ----------
Did you find that it didn't provide enough shielding without the 12mm extension?
01-09-2020, 12:16 PM   #10
QuoteOriginally posted by SpottyReputation Quote
The hood I used is for the film era Tokina-AT-X 28-135mm lens. I found it at HEH for $11.
I added the 12mm extension because I use the lens on APSC digital bodies and wanted a bit more depth. I have a screw-in metal hood for the 35-105 which is another 12mm deeper still. so if your leans have perfect threads (I had to repair mine-deep dent) and you shoot on an APSC body, a normal focal length lens hood will do nicely.
01-09-2020, 06:00 PM - 1 Like   #11
monochrome's Avatar
aSure - I’ll dig it out of storage.
12mm, 35-105mm f/3.5 macro, ebay, extension, hood, lens, lens hood, oem, photography, rubber, smc-a 35-105mm f/3.5, stack of primes, tokina
Pentax-A 35-105/3.5 Zoom ring "rattling" from 80-105 mm? Nayu Troubleshooting and Beginner Help 5 08-27-2017 07:03 AM
Tamron AF 35-105/2.8 & 28-105/2.8 GregL65 Pentax SLR Lens Discussion 4 03-01-2012 03:12 PM
All times are GMT -7. The time now is 04:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
