I would test the camera with the paper roll from the film, with the back off/open. Do what you would normally do to start a roll of film,click the shutter, advance, and so on for the complete roll. You should discover if the roll is advancing properly and if not. Listen to the wind lever to determine in you here any non-normal noises (sounds of skipping gears, etc.). Can it be fixed? Probably, as it was a manual camera with gears and springs. Finding a person for this work will be the trick. Possibly KEH.
Good luck!
