Originally posted by stevebrot Yes, that is expected. The lens stays wide open unless stopped down. What might be of concern is when shooting with lenses like the new D FA 70-210mm f/4.0 where the viewfinder might dim significantly and throw the meter off.
Yep...that "zone" represents the range where PDAF does not detect an OOF condition due to lack of sensitivity. The same issues exist for AF, though we tend to not sweat them too much.
Just so we're clear, with an FA77 lens, it doesn't matter if you shoot at f4 or f8, stopping down does nothing to the OVF experience, it's still showing and behaving like you are shooting at f1.8. This is the same as how it is with the stock focus screen. I think you know that it's just the way you worded it.
What you're meaning to say is that the new DFA 70-210, because f4 is it's widest aperture then it is already into 'dark/dodgy territory' and even though it will behave the same as the FA77 and that using the lens at f5.6 or f8 will still show a screen at its widest aperture (f4) but because that's pretty stopped down for a lens already then the experience could be problematic.
I have for example already used the Tak 135/3.5, and because 3.5 is its widest aperture it is quite a lot darker than looking through the eyepiece with the FA77 because even if I set the FA77 to 3.5 also the FA77 is still able to show me a nice f1.8 DoF and brightness that the Takumar cannot attain.
I understand the concern that a 'slow' lens would perhaps not be a very good idea to use with this focus screen.
Originally posted by stevebrot A few notes:
In regards to focus accuracy with the S screen, that you can assess by comparing on-tripod best effort (don't touch focus ring) to magnified live view. Adjusting requires messing with different shims.
As you probably know, issues with stop-down metering with non-A lenses are not unusual, even with the stock screen. A common fix is to use M mode and meter in live view. That same approach may be used if you have metering problems with slower (f/4 and narrower maximum aperture) A-contact lenses.
Yes I thought about that, just tripodding, getting a good shot with teh ovf and seeing if the LV is agreeing or not, and of course vice versa. I might Focus Chart later and see how much I might still be out. I do actually have more of these pads/shims that they supplied. Even if the focus is not bang on it's amazing that the hit rate is so much better already tho... which really says something about the stock screen imo.
Originally posted by iheiramo Thanks. I'll wait for the test report. As I shoot mainly with manual lenses I've been interested in chancing the focusing screen, but never have gotten to it , because I'm not sure about drawbacks. I have lenses like M*300/4, Tak 200/3.5 and M150/3.5 which I'd like to keep on using, so if you can test some f4 lens, it would be nice to read your comments.
I shall do my best to report back. My feeling is if you do use a lot of 'slow' lenses then yeah, this might not be the screen for you. I did however bang out some cracking shots with my Tak 135/3.5 yesterday however, it was helped by doing so outside on a bright day. I wonder if a UV filter and/or a CPL will just be too much for these lenses tho...
Originally posted by StarTroop I recommend reading that article as it suggests to calibrate the lens AF adjustments according to either of the exact points where the green hexagon illuminates, rather than guessing an arbitrary point somewhere within the illuminated range. The only caveat is that you need to calibrate by focusing from either beyond or before the illuminated range, and then in practice you must only focus from that same direction for maximum accuracy. It's a bit of a workaround, but it removes the ambiguity of the green hexagon by exploiting a consistent point of reference. For AF lenses being manually focused, you should be still be able to use off-centre AF points for focus check, and for manual lenses that are limited to centre point... well, focus-recomposing generally works for me. Maybe it's time to look towards mirrorless if you want a no-hassle LV experience in the viewfinder.
I've read the article before, and in fact came to the same conclusion as the author unaware someone had already been there and done that (and explained it far better than I ever could). My issues were;
1) My FA77 for example uses +8 for Fine Adjustments, it's good for AF but +8 might not be what I want for when I want to MF with it tho...
2) All Manual Focus lenses would have to use the same Fine Adjustment value as it's global.
3) For MF glass it's restrictive to centre point only, which I hate, I hardly ever take a shot with focus dead centre, and when using 1.4-1.8 focus/recompose is typically not good enough, it needs to be focus>recompose>refocus again, which lead me to just ignoring the hex completely and frame>focus>shoot.
What I decided was best is to just High Continuous burst and slowly rotate the focus ring throughout the burst, from near to far. One of the shots will be a keeper typically worked.
From what I can say on my preliminary experience thus far is that the feedback is just much clearer so that I can frame>focus>shoot with every shot being acceptably in focus first time (pretty much). This was not quite the same experience I would have with stock screen. Many factors matter, the stock screen was not too bad if focusing on something quite close to you, but far away it was very hard to tell.
