So... I was doing some some focus chart testing today, calibrating and fine tuning some lenses, when I came across this review method which I think worked pretty well for the K-1 and KP. Now before you all jump on your keyboards and start screaming "Bruce!! Focus Peaking only works for Live View and Fine Adjustments are for PDAF (Eye Piece focusing only)!"... I know that. Here's what I did and I wondered if this was a bonafide recommendation for completing Fine Adjustments/Focus Chart work (or not);
1) Set everything up, camera, tripod, chart at 45 degree angle etc etc.
2) Use Live View and Manual Focus mode to get perfect focus on the centre of the Focus Chart. Turn on Focus Peaking (to help, but also just leave it on at this point).
3) Take a shot.
4) Review your shot, and if you're happy with what you see then toggle back to Live View with Focus Peaking enabled, zoom in a little on the chart and you should have the Focus Peaking highlight things
perfectly symmetrical (the same amount of Focus Peaking Highlight information highlighted
above and below the centre of the chart).
5) Now switch over to the PDAF (OVF/Eye Piece mode), take a shot like you normally would for a Focus Test Chart shot (Single AF Spot Point bla bla bla).
7) Ignore the Playback/Review.
7)
Do not refocus
7a) Optional; if you can and feel comfortable, gently toggle the camera out of being in AF mode and place into MF mode
8) Hit the Live View Button which should also still have Focus Peaking on from last time.
9) Press the Ok Button to zoom in and check where the focus is, and essentially let Focus Peaking guide you as to how accurate the focus was from the shot before, how much front or back focus it has, does the focus peaking have more information ahead of the centre point or behind etc.
10) Make adjustments (if necessary) in Fine Adjustments, toggle back to PDAF/OVF, AF on and repeat.
Basically what I was finding is that once I took a shot through the OVF and get presented with a Playback screen, it's still hard to tell sometimes (lens dependent) where the focus shift is (if any). By ignoring the Playback screen entirely (turn it off in the menu if you like) and instead just toggle over to Live View with Focus Peaking enabled (after the PDAF shot), zooming in on Live Playback footage with Focus Peaking actually shows where the focus was when it was taken and thus provides
better feedback to the user as to where the front and back focus issues may be.
Cheers,
BB
