I'm in the UK, and I've been stuck away from home for the last few weeks thanks to Covid-19. I've been stuck at home with my mother in law and my 4 year old, so as you can probably imagine, I need something for me.
Tonight is one of the clearest nights we've had, and my daughter went to bed with no complaints, so I've actually got some time to myself. Great! I'll get the camera out and try to capture some star trails. I had a quick try when I first got here, but I needed a much longer shot / set of shots. I found a good spot and took some standard astrophotgraphy shots first, then realised that there were regular satellites passing over (presumably Starlink). Even better, they'll add something a bit different to the shot too. I set up, got myself comfortable, set a timer on my phone, and pressed the shutter in bulb mode. I waited for just over 20 minutes, then pressed the shutter again.
Nothing happened.
I was using a remote shutter, so I pressed it again just in case there was some kind of battery saving that I'd forgotten about. Still nothing. I tried the remote shutter a few more times, then tried the physical button, but still had no response. Ok, I thought, maybe it's the DFS as I've used bulb mode. I haven't used it for a while, so I'm not 100% sure how it works without double checking. I brought the camera inside* and waited for over 25 minutes, slowly defrosting my extremities (it was about 5c, so not cold enough to cause major problems). Still nothing. I tried several buttons on the camera with no luck, and eventually shut it off. I've just checked the memory card in my laptop, and there's no sign of the long exposure.
I've just wasted about an hour for nothing because my camera decided to stop working. The satellites are long gone, and as my daughter tends to wake up at about 7AM, I haven't really got the time to go back out and try another shot. The worst part is, the camera has just turned on at the latest attempt, and the batteries are showing as half full, so I don't even know why it stopped working
*Yes, I know that's not the best idea, but I wasn't going to sit outside for another 20 minutes in the cold.
