Originally posted by Deesquared A beautiful and moving project and fantastic images!!
---------- Post added 06-06-20 at 09:21 AM ----------
I think you should add prints of Jon Snow and Dualla to your rewards. Any possibility of that?
I’m also curious as to what kind of lighting you used. These are all so wonderful.
Hi there, Thank you for having a look at the campaign!
Jon Snow is available as a Medium print reward, and Dualla is available as a limited edition 16" x 20" print.
For most of the indoor photographs, I used bounced flash (the AF540). Actually, after the first two sessions, where I wasn't using flash, I realized I really needed to get better at working with flash. So I practiced with bounce flash a lot and did a one-on-one session with Neil van Niekerk.
When photographing animals, it can be quite challenging to work with flash. It can disturb them if the light is too strong. I found that the bounce flash was less disturbing for them. And that simple set-up for me worked well because I was often crawling around on the floor, stuck in cramped corners of rooms, even lying on my stomach or back to get a good photo. And the chickens would move, so setting up a light on a pole, using an umbrella etc just wasn't practical.
