My old card was, well old and also causing crashes and mouse freezes on my pc. So I've bought a new GeForce gt710 and installed it. All good so far. I then ran displaycal to calibrate my BEnq2420pt, a monitor with a calibrated gamma. My calibration device is a now, long in the tooth, Spyder 3. I've read various things about whether this device is reliable on LED monitors and indeed whether the BEnq even needs calibrating.
I ran displaycal after downloading the Argyle plugins for the Spyder3, using the default settings. The initial appraisal of the monitor it does showed it not to need any pre-adjustment and so I moved onto calibration.
The results I've got are quite different from previously and now I doubt what i see. It could be the old card was just faulty and I immediately noticed better detail and more saturated colours but I'm not sure if they are right.
So for instance if I look at the lagom site
LCD monitor test images in the white saturation window the square patterns take on a definite pink cast from 247 on, though I can distinguish all squares. For the Gamma test, well this has never worked for me in a browser and I generally download the images and view them in Photoshop and in there they display, with some variation, around 2.2, red being the furthest from this value, funnily enough.
To describe what I'm seeing, if I look at this website, I see a grey border and then, using the default style selector, a slight pink surround to the post box and indeed all quotes are in a slight pink box. The pink is darker and more obvious than it was previously.
If I remove the videocard gamma lookup tables using the option in displaycal, the whole display brightens slightly but my colours don't change. In general, colours look right in LR and PS but more saturated than previously.
If I run the windows calibration device and do it manually, I end up with a much brighter display, pretty similar to what I had before and the pink boxes on this website are more washed out but still visible and the pink cast on the lagom test almost gone.
The trouble is I don't know what to trust now. Help much appreciated.
