07-08-2020, 11:27 PM   #1
Paul Charlier's Avatar
Pentax DFA 150-450 on KP
Hi, I have a KP and have used my DFA 150-450 on it for the last year or so. It has been a great combo.
I have recently begun to get the F - - warning occasionally over the last month. It's a bit frustrating.
I cleaned the contacts with a microfibre cloth and it seemed to improve it somewhat. What is the best way to clean the lense/body contacts actually?
I always use a sash strap connected to the lense tripod mount as I think it gives better balance and theoretically stress the camera as much in my opinion.
Paul
07-08-2020, 11:48 PM - 1 Like   #2
I always use a microfibre cloth to clean camera and lens contacts, and find that works very well.
I also support off the tripod foot with a sling strap, works well.
Cheers,
Terry
07-08-2020, 11:51 PM   #3
pschlute's Avatar
Are the mount screws all nice and tight ?
07-09-2020, 07:03 AM   #4
sergysergy's Avatar
Use a little bit of alcohol, some dirt can be stubborn even if you cannot see it. As pschlute suggests check if the mount and the bayonet are tight.
07-09-2020, 09:57 AM   #5
Isopropyl alcohol is electrically conductive, so make sure the camera and lens are dry before re-mounting. You don't want signals jumping from one contact to the other.
07-09-2020, 05:23 PM   #6
Some people(including myself), use pencil erasers, but this can get sloppy because then you have to spray off bit and pieces of the eraser that cling to the contacts. A Q-Tip dipped in Isopropyl alcohol, or Vinegar is your best bet. past.
07-11-2020, 02:36 AM   #7
QuoteOriginally posted by tduell Quote
Cheers,
Terry
Thanks Terry
---------- Post added 11th Jul 2020 at 07:37 PM ----------
Not sure, I will check them out thanks Peter
---------- Post added 11th Jul 2020 at 07:39 PM ----------
QuoteOriginally posted by sergysergy Quote
Thanks Sergy
---------- Post added 11th Jul 2020 at 07:40 PM ----------
QuoteOriginally posted by hjoseph7 Quote
Don't think I will try the eraser, but the Q tip sounds doable. Thanks.
alcohol, camera and lens, check, contacts, dfa, f - - with dfa 150-450, jul, kp, mount, pentax dfa, photography, pm, post, terry, thanks
DFA 150-450 Reporting 310 when at 150 Mikesul Pentax SLR Lens Discussion 9 11-21-2018 04:18 PM
DFA 150-450 vs Sigma 150-500 gerax Pentax SLR Lens Discussion 26 05-21-2018 09:24 PM
Owners of Pentax 55-300 and 150-450 - Are you still glad you bought the 150-450? Joyce Keay Pentax K-70 16 02-17-2018 05:55 PM
Simple lens shootout Pentax HD DFA 150-450 vs Canon 100-400 II vs Sigma 150-600 C beholder3 Pentax SLR Lens Discussion 46 07-25-2016 12:33 AM
Nikon D7200+ Sigma 150-600 S vs Pentax DFA 150-450 Shanti Non-Pentax Cameras: Canon, Nikon, etc. 43 12-13-2015 09:02 AM
All times are GMT -7. The time now is 01:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
