07-30-2020, 08:16 AM - 4 Likes   #1
luftfluss's Avatar
Imaging Resource article on IBIS
The article is specifically about the IBIS implementation used by Olympus, but of course much of the information also applies to Pentax and other brands.
INSIDE Image Stabilization: Olympus takes us on a geek’s tour of what makes IS work
At their most fundamental, the way in which modern IBIS systems work is still very much like those in the early days, just with greater precision and sophistication. A number of permanent magnets arranged in pairs on the fixed portion of the sensor-shift assembly interact with electromagnetic forces generated by coils attached to the floating sensor carrier plate.
These are what's known as voice coils, and together with the magnets positioned above and below them they form voice-coil motors, so named because loudspeakers, headphones and the like use the same sort of mechanism to turn electricity into sound vibrations. Running an electrical current through a coil of wire creates a magnetic field that will push or pull against a nearby permanent magnet depending on the polarity and amount of current flowing.
In a camera or lens, the force generated by the voice coil motors lets the IS system move the sensor or lens element in very small, precisely controlled increments.
article, ibis, olympus, photography, resource article
Imaging Resource's CP+2018 interview with Ricoh Imaging Kunzite Pentax News and Rumors 93 04-18-2018 11:12 PM
Imaging Resource: Ricoh’s “Multi-Imaging Technology” pairs a K-1 with a Theta S EssJayEff Pentax News and Rumors 16 03-03-2017 12:05 AM
Imaging Resource Article on Ricoh Pixel-Shifting mgvh Pentax DSLR Discussion 26 03-30-2015 05:03 AM
Imaging Resource Article on Ricoh Aero Bright II Lens Coating mgvh Pentax SLR Lens Discussion 5 03-25-2015 12:16 AM
Nature Ibis, Ibis, everywhere photolady95 Post Your Photos! 9 05-11-2011 08:38 AM
All times are GMT -7. The time now is 09:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
