Originally posted by BigMackCam This is why I referred to buying the best (rather than the most expensive) lenses you can afford. As you rightly infer, the most expensive lens doesn't necessarily translate to better performance depending on what you shoot and how you shoot it. For example, there's no point buying an expensive constant aperture f/2.8 zoom if you're shooting primarily landscapes at f/8 - f/16 and can get similar performance from a good quality variable aperture lens covering similar fields of view...
Exactly!
And sometimes the definition of "best" takes one in directions far removed from optical test bench definitions.
For example, superzooms look like horror shows on the optical bench with all manner of distortions, aberrations, vignetting, and flare. But a superzoom may be the "best" lens for whirlwind tour-group travel that does not allow any time to switch lenses.
Sometimes the best lens has to be the one on camera.
