If this is going to be a flood the thread with images" thread, I'm in.
Panasonic ZS100 or FZ100
FF equivalent 24 to 250mm.
The features.
24-250 zoom, 4k video, collapsible front element makes it pocketable in a winter coat, or any jacket with big pockets.
Cons, for top quality work most of the long end is diffraction limited. F2.8 to F3.5 are pretty much your safe settings o avoid diffraction. The lens is 2.8 but by 40mm it's a minimum ƒ4. After that diffraction is noticeable.
So here is the quandary. The ZS1000 has an f2.8 to ƒ4 lens, to make diffraction avoidable, but the lens element is huge and it doesn't fit in your pocket.
This camera is seriously pocketable collapsing to a very small footprint. And used from 24-40mm equivalent, produces images comparable to K-3 images with it's 20 MP sensor.
That's my choice.
My wife loves her Q. (Two opinions for the price of one.)
These and out WG waterproof shock proof are our truly pocketable cameras. The Lumix is the only one capable of producing DSLR quality images. A measured 2600 lw/ph resolution, only 100 lw/ph less than a K-3, rich vibrant colours, and truly pocketable because of the collapsing lens.
---------- Post added 11-25-20 at 12:04 PM ----------
Originally posted by Wasp The bottom line, a lot of DOF without much control.
I always laugh at this FF proponent thought. As if superior DoF means less control. The difference is you have to work harder to keep your subject contained in the DoF with a larger sensor. If you want the DoF, you have more control with the smaller sensor. No stopping down to ƒ22 and, setting up your timers, and tripods and then getting a diffraction limited image to get wide depth of field. I don't call that control. Sensor size never affects control. It affects what you have control over. With FF you have control of narrow DoF, but ƒ16 and 22 will be effected by diffraction and lack of light for wide DoF images. With a 1 inch sensor you have great depth of field at ƒ2.8 for low light images with appropriate depth of field. The control is different, but not lacking.
You can do out of focus back grounds with a 1 inch sensor....
By going to ƒ22 you can do wide DoF with an FF sensor.
In both cases, using the sensor against it's strength brings limitations not found when using the preferred sensor for the job to it's strength. The smaller the sensor, the larger the DoF at a larger aperture. So increased shutter speed and the ability to capture images with good DoF in poor light are the control features of small sensor cameras.
Personally, I like the 1 inch sensor as a great compromise. Not so dramatic lack o DoF. Still big enough for 20 MP, a little disappointing in dynamic rage. Capable of images close to a k-3 in resolution. But most important gives my 24mm-250mm and fits in my pocket.
Here's an image 6 feet to infinity (ƒ22 on full frame) taken at ƒ3.2 and 1/400s to freeze the dog and and prevent motion blur. Try and take that with your allegedly "more control" camera. With larger sensors, what you gain on narrow DoF capability and flexibility, you lose on wide DoF capability and flexibility. It's a straight trade, with no winners or losers. You always need the best tool for the job to maximize your results.
