OK, after weeks without the sun, finally we had ~50% cloud coverage here on the big day. Seeing (i.e. turbulence) was bad as you can tell from the picture (e.g. no bands in Jupiter, the planet is not even round!) but I was at least lucky enough to have been able to see and shoot the event!
Attached is the first shot of the night, which turned out to be the only reasonable one out of 972 pictures I made. This is after cropping and 50% re-scaling. Three of Galilean moons (Calisto, Io and Europa from left to right) are visible. Blue/red fringes on top/bottom of the planets are due to dispersion of the air, not the optics used. The larger the wavelength (i.e. the redder the light) the more the light is bent toward the ground. The lower the planets/stars are in the sky the stronger the effect.
I used Pentax Q7 and Orion Space Probe 3 (a Newtonian telescope with 700mm focal length and 3" aperture that cost me 100 USD including tripods some years ago, though I didn't use that tripod in this picture), ISO 400, 1/25 sec. This dirt cheap telescope gave me stupid performance per price in the past (e.g. you can see much better Jupiter from the same combination here
Let's share shots with Q! - Page 433 - PentaxForums.com) but when the condition is bad there's nothing I can do about it. I'm still happy that I was able to capture something!
