There have been plenty of excellent responses already addressing the humidity concerns. I have found a couple other tangible benefits to using a dry cabinet aside from humidity control: they are dust-free and can be very space efficient.
I now have 3 of the Ruggard 120L cabinets that were all purchased on sale from B&H over the years. Some of my observations after adding the second cabinet can be found in
Electronic Dry Box - PentaxForums.com. My primary concerns are dust-free storage, maximizing the storage contents, and minimizing the amount of physical space required. Humidity control is a bonus. The current approximate dimensions for all three cabinets side-by-side are: 47" wide, 40" tall, and 17.25-20.25" from the wall (depth). One cabinet is further from the wall due to cable and network drops.
The 120L has the approximate footprint of a mini fridge and is just under 40" tall. The pictures of the 30L unit above in post #8 by ramseybuckeye shows one adjustable shelf. The 120L unit has 5 adjustable shelves. The holes in the supports to adjust the shelves are slightly less than 1 inch apart. The closest that two shelves can be set allows objects approximately 2 inches tall. The bottoms of each shelf are approximately 12.75" wide and 12" deep. The usable space is slightly larger than the dimensions of the bottom of the shelf. Due to the "boxes" mounted on the back of the inside of the cabinet (see the third picture in the post above), not all of the shelf mounting positions are feasible. As the shelves pull out, the shelves can be configured to minimize unusable vertical space. All of my lenses are stored standing up to maximize shelf contents.
To give an idea of the space efficiency, here are a few examples of what can be stored on a single shelf:
- 4-5" tall: 16+ (4 rows of 4) compact lenses (e.g., m42/k/m/a/f/fa/da primes) and teleconverters.
- 6+" tall: 9+ (3 rows of 3) larger/fatter/newer lenses.
- 5" tall: 6 digital bodies (K1, K3, K3ii, 2xK01[IR], A7ii) and a Panasonic superzoom
- 4" tall: 4 flashes (lying down without stands) and 3 triggers
- 2" tall: 18 batteries (cameras and camcorders) plus other miscellaneous flat items
The bottom of all three cabinets is used to store taller and/or heavier lenses. The bottom shelves (i.e., the distance from the bottom of the unit to the underside of the first shelf) range from 9-11.5" tall and hold between 9 (3 rows of 3) and 12+ (3 rows of 4) lenses. Access to items stored on the bottom shelf in the back typically require pulling out two or more lenses for access.
As the adjustable shelves are made of plastic, they can sag/deflect in the middle of the shelf due to the weight of the lenses. Careful organization and placement of lenses can mitigate this problem (e.g., heavier lenses on the sides and lighter lenses in the middle.
If you decide to go with a dry cabinet, I suggest going with a cabinet that is a little larger than your current needs to allow some room for growth if your budget allows. In addition, the more adjustable shelves there are in the unit the more options there are in configuring, and then later reconfiguring, the available space.
