We've been through this so many times.
As for the crop argument.
Smaller sensors for the most part have smaller pixel sites producing more definition in the area of the crop.
It's debatable which is more effective, tight framing on a crop sensor or much looser framing on an FF sensor. You might get better composition on an FF camera. Most likely not but it could happen. You will definitely get more subject resolution on a crop camera, unless shooting FF over 54 MP, or 645 over 108 MP.
So if your at all into resolution, you either choose 54 MP or thousands of dollars more to get the same crop image as you would using APS-c.
Consider the APS-c image pre-cropped.
People are claiming you get better crops, but they aren' showing examples. maybe stop as yin it until you actually try it and prove it. The laws of physics say you're probably wrong 99% of the time. Talking about ice in a life time shots is pointless. You will have once in a life time shots once in a life time. You can uy a camera for your once in a lifetime shot... but so far I've probably owned 15 cameras in my life time. The odds that you'll get a once in a life time shot with s camera you buy next are 15-1 against you having that camera when your shot comes around, if you haven't already missed it. And the odds of the camera you have with you being the right camera for the jog depends on many other things besides megapixels. You could miss your once in a life time because you have too large a sensor and don't have the DoF you need at ƒ2.8. You could miss your once in life time because you left the right lens home and could have had the shot with something like the much despised 18-300. You could. miss it because the small pixels on your megapixel camera don't have enough dynamic range. Or you could miss it because your heavy gear is slow and cumbersome or too difficult to use ergonomically.
More megapixels provide few if any advantages after 16 MP. And much of the time, you can't tell the difference between 36 MP and 24 MP unless someone tells you which is which. Then you can go all nitpicky.
Pentax is going in the right direction with the evolution of the accelerator chip.
IN camera crop, in camera noise reduction. Look at the DXOMARK rankings. The Pentax 645z is still ranks #2 and the K-1 #11
The 51 MP Canon produces such inferior images, it's so far down the list you have to scroll down 3 pages just to find it. These are images that have been normalized for noise and resolution. SO bottom line, at present, more MP means inferior images.
Someone let me know when it changes.
Until then, keep hoping or the tech advances that will mean a 51 MP comer out performs a 36 MP camera. Someday in the future there may Coe a time when more MP is actually better. No-one has been more critical of what DxO means over the years. But, it's true standardized testing. It means what it means. If you do the same thing every time for every camera, the ranking will have some meaning.
I'll take that over the google eyed cawing of new camera purchasers any day. If you want the camera in your hands for the perfect opportunity, once in life time shot, you want one of these 14.
Hasselblad X1D-50c
102
Pentax 645Z
101
Panasonic Lumix DC-S1R
100
Nikon D850
100
Sony A7R III
100
Sony A7R IV
99
Nikon Z7
99
Sony A7R II
98
Nikon D810
97
Sony Cyber-shot DSC-RX1R II
97
Leica Q2
96
Pentax K-1
96
Nikon D800E
96
Sony A7 III
96
And those images will all be pretty much indistinguishable. It takes a diference of 5 DxO points to be distinguishable pixel peeping, At reduced size for normal viewing, there will be no discernible difference. People who buy expensive gear with high MP would have done better with one of the 14 cameras listed, and possibly saved a pile of money.
If I had a million dollars I'd put it up as a reward for whoever could prove me wrong. Pictures with artifacts, noise, heavy noise, cross talk at pixel level and low DR etc. are not what you want for your once in a life time image. Some have this all wrong. The camera most appropriate for the job is what you want. Assuming that will always be the highest res camera possible is a mistake. You're probably more likely to miss achieving your once in a life time shot because you have a hi res camera as any other reason. The Canon 5Ds will be noticeably worse than any of the 14 cameras I listed, by a considerable margin, almost certainly visible at normal viewing. So actually in practical terms the opposite of what has been stated is true. For your once in a lifetime shot, you don't want a hi res camera. Maybe at some point in the future, but not now, and possibly not ever.
If you consider the DxO figures accurate for one testing procedure and set of applications, the 5Ds isn't really any better than a K-5ii. People need to contemplate that for a while. That isn't based on any MTF numbers but those are based on real world image quality, ie the real world. No hype involved.
So bottom line....the highest MP cameras do not produce the best images.... unless you're buying a hassy, and the Hassy is only marginally better than a K-1, for what 50x the price? The costs of larger files, slower post processing etc. makes really high MP a really expensive mistake as far as I can tell, taking advantage of the gullible.
