03-04-2021, 08:18 PM   #1
akptc's Avatar
How long can lenses safely survive in a dry box?
Like many Pentaxians, I have accumulated more gear than I have time to use. The unused and rarely used lenses live in dry boxes at 35% average humidity. What is the smart thing to do to make sure they remain in great condition? Can they just sit there for years and be fine? Should I take them out from time to time and expose them to sunlight just in case? Fungus is a concern of course but also things like SDM - I am told to exercise the 300/4 from time to time otherwise the SDM may not work when I need it. All input will be greatly appreciated.
03-04-2021, 09:17 PM   #2
UncleVanya's Avatar
Sdm exercise is nothing scientific. It may help. It may just be magical thinking.
03-04-2021, 09:20 PM - 1 Like   #3
Paul the Sunman's Avatar
Do you really have the DA*300 packed away in limbo?
03-04-2021, 10:06 PM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by Paul the Sunman Quote
Is that a hint there is a forever home waiting for it Downunder?
03-05-2021, 02:40 AM   #5
ramseybuckeye's Avatar
Maybe I’m wrong, but I was under the assumption that what you are doing may be the ideal method of storage.
03-05-2021, 03:41 AM - 1 Like   #6
JensE's Avatar
Some occasional mechanical movement for lubricated parts (focus, zoom, some aperture mechanics parts in some lenses) is advisable.
03-05-2021, 04:27 AM   #7
QuoteOriginally posted by akptc Quote
35% RH seems way too low i think.
Setting it at range of about 50% to 55% should be just about right.
03-05-2021, 05:06 AM   #8
gordon_l34's Avatar
Hi,
I have all of my dehumidifiers set at about 50% RH as I have been lead to believe that down around 35% RH it dries the grease out in the lens and above 60% RH that is when our friendly fungus can grow!
Regards,
Gordon.
03-05-2021, 07:19 AM   #9
ChristianRock's Avatar
If there isn't... here in the state of Georgia there's a place where the DA*300 could get some regular exercise
Seriously though, 50% humidity should allow it to be kept for a long time with no issues.
03-05-2021, 08:54 AM   #10
Low humidity has little affect on grease since humidity is a measure of water content in air which doesn't affect the rate at which grease solvents evaporate. Lower humidity won't introduce any bad effects (unless you have dry skin to worry about) so going below 50% is probably better than 50% for long term storage (it makes fungus growth less likely). Grease does dry out over long periods, but that's because it loses some of its original solvent base. You can reduce this evaporation if keep the lenses cool (hint: don't store your lenses where they will get hot). Also, bagging the lenses in sealed (zip-lip) poly will prevent long-term storage dust issues but be sure to include a desiccant in the sealed bag and check those once in a while for depletion (some moisture can migrate through poly).
03-05-2021, 09:23 AM - 1 Like   #11
jatrax's Avatar
I have any number of Takumar lenses that were stored at room temperature and humidity for 30 years or so with no ill affects. The lenses that I have handled that developed fungus did so (IMHO) not because of storage but because they were put away wet. I cannot prove that but it does make some sense. A normal home environment, healthy to humans is dry enough that fungus does not develop on walls, floors etc. So it is not going to develop on lenses either. But if you get something wet, put it in a closed camera bag so the moisture cannot escape readily, then yes you get fungus.
So rule number one is to never, ever put your gear away damp or wet. Leave everything out on a counter in free air until it is completely dry. The use of a dry box or other mechanical drying system will certainly work also. And if you frequently are shooting out in the wet a dry box would be a good investment to dry your gear when you come in.
According to information published by the EPA mold growth can happen if relative humidity is 60% or above. They suggest keeping home humidity in the 30 to 50% range with 45% being ideal for human health. Too low can cause health issues as well.
So a dry box at 35% will certainly prevent fungus growth indefinitely but it could be set at 40 or 45% to achieve the same result.
03-05-2021, 09:27 AM   #12
Wheatfield's Avatar
I live in a drybox climate, so no worries about fungus. I've had lenses in storage for decades (literally), and they are just fine and dandy. The biggest problem you will likely have is lubricants drying out causing slow aperture response.
03-05-2021, 11:51 AM - 1 Like   #13
QuoteOriginally posted by ChristianRock Quote
And in North Carolina.....
03-05-2021, 07:44 PM   #14
akptc's Avatar
I know, it's a travesty
---------- Post added 03-05-21 at 20:46 ----------
QuoteOriginally posted by termy Quote
Thank you, I was not quite sure about this number.
---------- Post added 03-05-21 at 20:47 ----------
Indeed I am worried about that.. will start with higher humidity setting at 40-50% and occasional exercise of the lenses.. I guess that's all that can be done..
03-05-2021, 07:58 PM   #15
Wheatfield's Avatar
Don’t sweat it. I have a 77mm LTD and an A*85/1.4 in storage.
I suspect I’m going to burn in h**l for that.
dust, lenses, photography, post, sdm, time
Cheap DIY Dry box for storing lenses Urs Photographic Technique 6 11-14-2020 10:26 PM
SD cards can survive a lot... bertwert General Photography 5 06-24-2016 09:23 PM
Can I safely use any of these old lenses on a K5? pyrs n finns Troubleshooting and Beginner Help 5 01-27-2014 02:05 PM
Can I safely use Vivitar 285HV with K-5 using Wein Safe Sync or Pentax PX cord? Dnabors Troubleshooting and Beginner Help 7 06-13-2012 12:05 PM
Can the world economy survive without Made In China? Reportage General Talk 47 12-27-2010 11:42 AM
All times are GMT -7. The time now is 04:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
