Show Printable Version 24 Likes Search this Thread
04-15-2021, 03:26 PM   #1
Paul the Sunman's Avatar
A very specific bag requirement.
Yes, another "Which bag should I buy?" thread. But for this one I have very specific requirements.
I am looking for a backpack or preferably a sling-pack that can accommodate my standard street/walk-around kit:
  • DFA* 70-200
  • DFA 15-30
  • DFA* 50
  • K1, ideally with one of the above lenses mounted.
If it could also hold the DFA 28-105, that would be an advantage.
I currently use a Lowepro 202AW, but that only holds the basic kit if no lens is mounted on the camera, and even then, the DFA* 50 has to go in the top compartment meant for non-photo gear.
Everything goes nicely in my Vanguard Up-rise II 38 messenger bag. That bag is perfect for taking gear to a fixed location, but I don't like messenger bags for walk-around, particularly if using a sling strap for the camera/lens.
So, something as compact as possible for this kit, and accessible without taking it completely off your back. All suggestions welcome.
P.S. I have a Peak Design camera clip, but find it unwieldy for the K1. It's more suitable for an APS-C camera for me.
04-15-2021, 03:39 PM   #2
david94903's Avatar
Think Tank Street Walker Pro is a great backpack that should meet your needs. I have a similar set up with mine except I have the DFA 150-450 instead of the 70-200.
04-15-2021, 04:00 PM - 13 Likes   #3
pschlute's Avatar
QuoteOriginally posted by Paul the Sunman Quote
DFA* 70-200
DFA 15-30
DFA* 50
You don't need a bag, you need an assistant
04-15-2021, 04:06 PM   #4
For the past year I've been using the Lowepro Passport Sling III. It would probably hold the gear you listed even if a bit tight, plus space for a couple of spare batteries, a small case for SD's, and a lens blower. As much as I use it it has held up really well.
BUT...
I should be receiving the Top Shelf camera bag in just a few more weeks which I'm hopeful will be an even better fit for my gear, and would appear very capable of holding yours. Having a solid surface for changing lenses will be a godsend. Granted it's not particularly inexpensive, but not really over-priced either.
04-15-2021, 05:30 PM - 1 Like   #5
I like the assistant idea! often also called girlfriend, wife, brother and if your not careful -- it'll be in that order ....
04-15-2021, 05:39 PM   #6
QuoteOriginally posted by travelswsage Quote
Unfortunately, the wife is more than happy to send me on my way unaccompanied. In any case, weight is not an issue, just organisation.
---------- Post added 16-04-21 at 10:52 AM ----------
QuoteOriginally posted by gatorguy Quote
Yes, I saw the Top Shelf online a while ago. It looks very interesting, though pretty expensive. I hope it works for you.
04-15-2021, 06:14 PM   #7
Imp
Imp's Avatar
QuoteOriginally posted by david94903 Quote
Is there a difference between the Street Walker and the Street Walker Pro? They look identical to me, besides a slight price difference.
04-15-2021, 06:21 PM   #8
QuoteOriginally posted by Imp Quote
Size. The Street Walker is the smallest, then the Pro, then the Hard Drive.
04-15-2021, 07:21 PM - 1 Like   #9
ZombieArmy's Avatar
If he doesn't mind paying for a ticket to Melbourne I can hold some expensive Pentax gear
04-15-2021, 07:31 PM   #10
I like to use a normal hiking backpack with inserts. It doesn't scream expensive photography equipment inside.
04-15-2021, 07:37 PM   #11
I use a Canon 200 EG backpack. It'll handle your list.
04-15-2021, 08:51 PM - 1 Like   #12
Have you tried the Lowepro Flipside 300 AW? I think it can hold all of what you want to carry.
04-15-2021, 09:42 PM   #13
Hi Paul,
I have had the Think Tank Street Walker Pro for a couple of years to usually house my K1, 150-450, 540 flash, pair of binoculars and occasionally a 24-70 as well. I really like this pack as it is very sturdy with strong straps & zips and is comfortable when full (~10kgs). It looks like normal backpack. I have taken it fully loaded on flights interstate a couple of times and it performed well.
I did a minor re-structure of the pack to show you how much room you might have for your gear. In the photo below is the 70-200 on the K1, the DFA 50, a DFA85 (slightly smaller than your 15-30), the AF540flash and easily enough space for the 28-105 and possibly more if organised properly. It has numerous, well designed pockets and pouches as well. I believe it will accommodate your gear easily (and might be a bit too big?)
PM me if you want to have chat about it.
Geoff
RICOH GR III  Photo
04-15-2021, 10:16 PM   #14
QuoteOriginally posted by RedBoomer Quote
Hi Paul,
I have a somewhat larger Tenba bag of similar design. Very useful for travel, but not so convenient for access. Looks good though.
04-15-2021, 10:44 PM   #15
Sandy Hancock's Avatar
My Peak Design Everyday Messenger, and Domke Metro Messenger, both comfortably accommodate exactly that kit.
The PD looks snappier, and is a little more compact.
bag, camera, dfa, dfa*, gear, k1, kit, messenger, photography, shelf, wife
Topaz Plugin New 64-Bit Requirement k0og Digital Processing, Software, and Printing 21 09-09-2015 05:19 AM
Very Specific Dilema Ian G Pentax DSLR Discussion 15 11-09-2010 05:58 AM
Specific bag for K10D+grip + 7+ lenses.. aCIDfire Pentax Camera and Field Accessories 3 03-27-2009 10:24 AM
Question URL requirement when leaving feedback - WHY?? ChipB Site Suggestions and Help 4 09-08-2008 08:05 PM
All times are GMT -7. The time now is 01:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
