Originally posted by AlanM That's what I would have thought as well. Yet, you see photos of snowy landscapes. How is that accomplished? Keeping the camera warm in some kind of "heated" bag? What would be the best way to avoid condensation/freezing if going on a long hike in winter?
Be sure your camera gear is "dry" where it is stored. Various "drier" products are available for this purpose.
Your gear in a controlled environment is you friend, and should be a consideration for routine storage.
How long the hike is really does not matter, any condensation will happen as soon as the gear is chilled; continuing to get colder may cause freezing.
I think you are looking for a problem that you may not find, winter air in your part of the world is pretty dry, I'm guessing the humidity inside is also low.
If your inside air is 30% relative humidity and you go out into zero degrees, the outside humidity is likely even lower and any moisture will "evaporate" or flow to the less moist outside air.
It is much more likely that you will get condensation on the outside of the gear when you return to a warmer, more humid environment.
As pointed out above, a sealed camera may be an exception- so store your gear in a controlled humidity environment, even if it is just inside a bag with a container of silica gel.
