i think the concern was with the autofocus when using slower lenses, check the in depth review:
Quote: Conclusion
The rear converter has no significant effect on autofocus speed at normal light levels as long as lenses F4 or faster are used. In dim light the loss of one F-stop of light with the converter will result in slower autofocus, as the camera will require more time to make up for the lost stop of light while making its calculations.
For lenses slower than F4, contrast detect (live view) AF works best while viewfinder AF may be unreliable.
We would not recommend using the 1.4x Rear Converter with wide lenses or with consumer zooms like the SMC Pentax-DA 50-200 F4-5.6 or 55-300mm F4-5.8 lens due to autofocus limitations. Viewfinder (phase detect) autofocus works best with lenses F4 or faster (live view must be used for reliable AF with slower lenses), and the converter amplifies lens flaws so it is preferable to use it in connection with top shelf lenses only
Read more at:
https://www.pentaxforums.com/reviews/pentax-da-14x-aw-af-rear-converter/conc...#ixzz6uDHq34Xb
my only problem with using the D FA 150-450mm with the teleconverter is trying to hold it steady enough to shoot without a monopod or tripod
some times I can, other times, it is very hard to do so
