Originally posted by DeadJohn Consider adjusting the type of photography that you do to match your physical capabilities, your home, and the available subjects.
- Macro and still life photography can be done at home.
- If there are busy streets near you, try street photography.
- If you live far from an urban center, try night astrophotography from your backyard.
- Shake reduction and ISO improvements make the monopod/tripod less necessary than in the past.
- Look for good locations you can easily travel to. What's within your walking capabilities? Is there a reliable mass transit system? Is a weekly taxi or Uber trip to a good spot within your budget?
- I'm not prying into your medical conditions, but *if* your walking distance is more limited by being out of shape than by permanent conditions, use photography as an excuse to walk more.
I am interested in Macro and still love photography, and will be rearranging some books and furniture to make space to do this today.
I live within reasonable walking distance to a popular beach, and will revisit it periodically with my camera, trying different lenses on different days to get a broader sense of what each lens can do.
There is a fairly good transit system where I live, and there are options to travel north or south to visit two other smaller cities.
My budget is a bit tight right now, but things will improve in a month or two. I can't afford long trips, but will explore all of the different communities that can be reached by bus + a bit of walking.
I am using photography as a way to get out and walk more, but my semi-permanent back issues (I might need back surgery) limits how far I can walk, and every day that limit is different.
I recognize the value of and the need to reduce the amount of weight I am carrying on my body itself. A loss of 20 - 25 pounds should be doable. I bought a used mountain bike last year to help me get more exercise, but my doctor hasn't cleared me to use it as I am having some balance issues. If/when that happens, I can increase my photography range, work on getting fitter, lose a bit of weight, and have a more efficient way to get around.
One thing is certain: I am not giving up on photography, regardless of my ailments. I am simply trying to chart a sustainable path forward. With thoughtful responses like yours and the other responders of this thread, I will make it happen. Thanks for your input!
---------- Post added 05-17-21 at 11:15 AM ----------
Originally posted by UncleVanya My dad went to m43. Then to a Sony RX100 mk V. I often have used m43 or smaller cameras but mostly just for simplicity and storage space on a trip.
I can recommend carrying only a few primes as one method to reduce the load. The KP is a lighter body that may fit your needs also.
There are many lightweight carbon travel tripods that work wonders paired with a wireless remote. This works very well with smaller lenses.
Manual focus primes can be lighter also.
I thought about going with an M43 camera and lens package, but didn't for two reasons: The smaller sensor size/higher pixel density, and the higher costs. Going with my Pentax K-50 and being able to use older manual focus lenses gives me more versatility for lower cost. Ideally, I hope to buy two good prime lenses to cover the 50mm+ to 100mm range. Once I do that, I will leave my kit lenses at home, unless I need to do some photography out in the rain.
