All of you should check out:
Focal-plane shutter - Wikipedia
There are two basic types of focal plane shutters used in SLR's. Horizontal (like my Fujica SLR's) and Vertical (like all of my Pentax DSLR's) - please note the difference in the letter
D.
For X sync flash, it will only go off when the shutter is fully open. In the case of my Fujica's it was 1/60th of a second - the flash duration of my strobe was 1/2000th of a second. On all of my Pentax bodies the X sync is 1/180th of a second. Meaning that the flash will go off when only when the sensor is fully exposed.
In order to achieve shutter speeds above 1/180th of a second, the second blade (talking vertical here) will start to move leaving the exposure time at each point of the sensor to be what is dictated. The second blade release is electronically controlled (since the early 70's with Aperture Priority cameras hitting the market - i.e. Fujica ST-901). This means that all shutter speeds above 1/180th of a second are obtained by having a slit (distance between the first and second blades) moving across the sensor.
The speed that the blades move vertically is constant, I will let the arithmetic people figure out the speed - I don't care. The size of the distance between the blades is what determines the shutter speed.
