Originally posted by Lowell Goudge It’s all a question of the era of the sensors,
I agree.
The theory that a larger pixel catches more light and COULD perform better makes some sense, it follows a bit the film era logic of high ASA filmrol with larger 'grain' chemicals. But in reality the electronics sensor design and technology (generation) matter more.
The problem is that in chip and sensor design one can not scale the pixel size and pixel count by just in-/de-creasing the physical size of the electronic components like ’pixels'. On the sub micron level of electronics , size influences timing of signals, noise, cross talk... and much more. None of them scale linear with the size of the components on the chip.
It just becomes a new design if you have different, higher density pixel count for same sensor size, even with similar technology. Sensors are designed for specific sizes and pixel count. Sensor technology evolves fast and almost every design tends to be different, even when using similar technolgy.
I remember of one panasonic camera that once claimed better performance in low light with lower pixel count than its predecessor. it created a bit of a marketing fuzz - going to lower pixel count was against market(ing) trends....even then in 2015.
But it involved also new sensor technology - HS MOS versus CMOS , maybe they had still trouble to create high pixel counts on the new, first chip-versions of that HS-technology. As you can guess higher pixel counts followed later on.
I quote the sales text at launch:
" The LUMIX ZS50 features a 12.1-megapixel High Sensitivity MOS sensor, ultra-wide-angle 24mm LEICA DC VARIO-ELMAR lens and 30x optical zoom for amazing versatility and performance ...... (sensor) that offers a one-stop improvement in noise compared to its predecessor (the ZS40). "
The predecessor ZS40 was 18 mp CMOS sensor... so definitely other electronics design and technology. So even that is no proof of contribution of pixel size effect alone, maybe it contributed.
I haven't seen other vendors seen doing this. (feel free to fill-in)
And : my 10mp k10D is less good than my 24 mp k3II in low light. It was one of the main reasons to upgrade . Even my family's newer small pocket camera's started to outperform the aging k10 in low light around the time the k3II appeared on the market. So my larger DSLR kit was challenged , hence upgraded to k3II
