Originally posted by brainwave What is the key difference between mirrorless and D-SLR that makes them the "future", so to speak?
Primarily computational photography (CP), and it's not really here yet. By 'computational photography' I mean the ability of the always-exposed sensor to capture a light information stream that extends both before and after you actually press the shutter, and use all that information to calculate or build up what the scene must have been, through frame stacking and other means.
The primary issues with this are that (1) there's no 'real' camera available today that does is as well as a top-notch cell phone, (2) it's still fairly primitive: 'artificially enhanced' reality isn't good enough yet, and (3) there's no camera available today that's 'future-proof' on this capability: current cameras lack the power to fulfill the promises of CP, even if the necessary software were available.
So future or not, there's no current reason to switch.
traveler
---------- Post added 09-29-21 at 04:04 AM ----------
Originally posted by MadBill ... what one sees in the viewfinder is a closer approximation of the image that will be captured...
I've always had an issue with the WYSIWYG claim.
Sensors capture data--the closest we get to that is a raw file. But a raw file isn't directly viewable--it has to be interpreted to be displayed on the electronic viewfinder, and that interpretation is susceptible to all the limitations of in-body image conversion. Rather than 'what-you-get', and EVF shows you a fairly 'neutral', speed-optimized rendering of the raw data that might or might not correspond to what the photographer would actually do with the image in post.
So an EVF shows you neither the world actually out there nor the final image, but some intermediate thing that, if the photographer shoots raw and 'processes to taste', might never be seen again.
traveler
