11-25-2022, 04:19 AM   #46
Whatever they put into those little gas dusting cans that come from the office supply store.
I once cleaned a focusing-screen of the split image type with canned air. It changed it's color, was useless afterwards.
The air was too cold. So that stopped me from ever using canned air for sensor or pentaprism cleaning.
Also the pressure can be quite strong, danger for seals, hinges etc.
The airflow of a sensible vaccumcleaner can be adjusted, with an adapter and thin tube one can reach very easy into smaller regions without any danger of "sucking" something up that could go out of alignment. That is my experience.
11-25-2022, 04:19 AM   #47
Fogel70's Avatar
Aha, I thought you used flammable gas to burn the dust away, instead of wet cleaning.
11-25-2022, 04:26 AM   #48
Unregistered User
Guest
I'm very surprised no one has suggested putting their camera in a tumble dryer - they certainly get rid of the dust/lint on my clothes.
11-25-2022, 05:35 AM   #49
Wheatfield's Avatar
QuoteOriginally posted by photogem Quote
This is literally a first. Every time on any forum that I mention this I get a barrage of warnings, but never any actual facts regarding how harmful canned gas can be.
I did check the MSDS one time and found the liquid used has a boiling point of somewhere in the range of -20°C, so it's chilly if you spray liquid propellent, but I'm very surprised it was cold enough to damage a screen as I routinely use cameras when it's colder outside than that.
If used properly, meaning one is just getting gas, not liquid, it's nowhere near that cold.
I'm wondering if there isn't a correlation/ causation thing at play here.
body, dust, modification to vacuum, photography, sensor, tube, vacuum
Ok to swab focusing screen with sensor cleaner tool/solution pentaxian_tmb Repairs and Warranty Service 9 01-09-2017 01:24 PM
Macro Vacuum Cleaner Rense Post Your Photos! 8 05-10-2010 01:48 PM
Dust on sensor - blow or vacuum? johngs Troubleshooting and Beginner Help 2 04-04-2009 05:57 PM
Can the sensor cleaner be used on the mirror. pcarfan Pentax DSLR Discussion 4 04-14-2008 10:44 AM
ASK THE DUST - Vacuum sensor cleaner superfuzzy Pentax DSLR Discussion 4 01-05-2007 12:26 PM
All times are GMT -7. The time now is 06:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
