A pf member (tuco?) showed a graph from a very old photography booklet. It shows the relationship between field angle, format sizes (film) and focal lengths. The (diagonal) field angles are divided by color into type of lens sections. Approximately as follows …
Extreme Telephoto: not strictly divided by color, i guess up to 10 degrees
< Medium Telephoto: guessed 10 degrees up to around 26 degrees
< Moderate Telephoto: around 26 degrees to around 45 degrees
< Normal: around 45 degrees up to 60 degrees
< Moderate Wideangle: 60 degrees up to around 72 degrees
< Medium Wideangle: around 72 degrees up to 90 degrees
< Extreme Wideangle: 90 degrees and wider
As far as I know ultra wideangle is a synonym for extreme wideangle. The angle of view for your digital camera - lens (focal length) combo you can get by example via app photopills.
Reason: Hint synonym ultrawide - extreme widangle added.
