Not sure if this should be here, or in the Compact camera section, but since other brands are also discussed and this subforum gets more traffic, I'm erring on the side of a properly exposed thread
... if it's inadequate, mods please move!
So, recently I've (after postponing it for just a decade or so) finally gotten my Open Water Diver certification. Since I also enjoy freediving, I have a cheap GoPro knockoff (Rollei s9), that I carry with. However, the image quality of the thing is...
suspect. Exhibit A:
I should have known better than to cheap out, but the camera's video is actually pretty decent so worst case it will go with my brother to mount on his speargun (or mask) to document his fishing outings.
The question makes itself, then. I am once again asking for your money-spending counsel. Current situation is not particularly buoyant (pun intended) but I love the underwater too much to not try and get decent photos - a DSLR housing is absolutely out of the question, but I've thought I could stretch myself a bit and get at least a better option.
Options I'm considering:
-Ricoh WG-6. This is, I
think, what I would prefer, for two reasons: It is rated down to 20 m (for two hours, IIRC), and has a LED ring for macro which I find extremely appealing. It is also reasonably priced. The one and only con is that there is no option for a housing, so if anyone has taken this baby at the usual 18 m depth for OWD, please do let me know if it's a reasonable option or if the waterproofing is NOT valid for that...
Nikon Coolpix W300. This one is even more waterproofed (30 m!) so this one should not need a housing... As cons, it loses the LED ring, and its close focus is not particularly good either. Also a bit more expensive.
-Olympus TG-6. I've seen this one underwater, has housing options, good macro mode,
probably same lens and sensor as the Ricoh. The only thing is that its waterproofing is down to 14 m so I figure it absolutely would need a housing... and thus it gets to be pretty expensive.
-I'd prefer a "proper" camera experience, but a
GoPro or similar "premium" action cam is a dependable option as well.
Any comments or suggestions? Other options I have not considered? Thanks a lot in advance!
