It's a mirror lens, right? The bokeh must be terrible...
Focal length 131.4 meters, and I guess
Quote: "Diameter of primary Mirror: 6.5 m (21.3 ft) approximately
Clear aperture of primary Mirror: 25 mē
means something like 131.4/5.6 = f/23?
What about diffraction, is that more or less of a problem in the infrared spectrum (My guess: less?)? How big is the sensor?
I hope they have something like MLU and there's no shutter shock
Regarding shutter:
Quote: Near Infrared Spectrograph (NIRSpec) Instrument Webb/NASA
One unique technology in the NIRSpec that enables it to obtain those 100 simultaneous spectra is a micro-electromechanical system called a "microshutter array." NIRSpec's microshutter cells, each approximately as wide as a human hair, have lids that open and close when a magnetic field is applied. Each cell can be controlled individually, allowing it to be opened or closed to view or block a portion of the sky.
It is this adjustability that allows the instrument to do spectroscopy on so many objects simultaneously. Because the objects NIRSpec will be looking at are so far away and so faint, the instrument needs a way to block out the light of nearer bright objects. Microshutters operate similarly to people squinting to focus on an object by blocking out interfering light.
(Read more about NIRSpec's microshutter technology.) That's cool! Though, magnetic field sounds like solenoid. I hope they found a source for the good white Japanese ones
Quote: Mirrors Webb/NASA
A oval mirror, for example, would give images that are elongated in one direction.
Would that result in some J.J. Abrams anamorphic lens-flare like effects?
Quote: "Aligning the primary mirror segments as though they are a single large mirror means each mirror is aligned to 1/10,000th the thickness of a human hair. What's even more amazing is that the engineers and scientists working on the Webb telescope literally had to invent how to do this."
I smell a patent infringement coming from Pentax
Do we have any data how precise the Pentax IBIS is in "thickness of a human hair" speech?
Quote: Aligning the Mirrors on Earth and in Space
Once the telescope is in orbit, Engineers on Earth will need to make corrections to the positioning of the Webb telescope's primary mirror segments to bring them into alignment - ensuring they will produce sharp, focused images.
These corrections are made through a process called wavefront sensing and control, which aligns the mirrors to within tens of nanometers. During this process, a wavefront sensor (NIRCam in this case) measures any imperfections in the alignment of the mirror segments that prevent them from acting like a single, 6.5-meter (21.3-foot) mirror. Engineers will use NIRCam to take 18 out-of-focus images of a star - one from each mirror segment. The engineers then use computer algorithms to determine the overall shape of the primary mirror from those individual images, and to determine how they must move the mirrors to align them.
Can we get that focus system for our cameras?
Sounds like Canon's dual pixel af x9?
Quote: Infrared Detectors Webb/NASA
Webb has extended the state of the art for infrared detectors by producing arrays that are lower noise, larger format, and longer lasting than their predecessors.
That's just mocking camera manufacturers' marketing bullshit, isn't it?
Quote: Each Webb H2RG detector has about 4 million pixels. The mid-infrared detectors have about 1 million pixels each.
Doesn't sound like much. My K-1 has 36 million pixels
Quote: It is possible to read the pixels in a Webb detector more than once before resetting them. This provides several benefits. For example, it is possible to average multiple non-destructive reads together to reduce the read noise compared to doing only one read. Another advantage is that by using multiple samples of the same pixel, it is possible to see the "jumps" in signal level that are the tell tale sign that a cosmic ray has disturbed a pixel. Once it is known that a cosmic ray has disturbed a pixel, it is possible in ground based processing to apply a correction to recover much of the scientific value of the affected pixel.
Just amazing how much engineering went into every little bit of this project and I hope it succeeds in delivering imagery for 10 years and more.
