Originally posted by VSTAR To make the lcd clear with your glasses being worn would require an optical device to enlarge and focus the screen to wear your eye is located, and that is the Hoodman type device that others have already indicated. To make one small area of the lcd to have high enough resolution to use as an EVF with a lens in front …you would need an extremely high resolution lcd, IMHO not practical. Here are a couple of practical choices that may help you. First, there are flip up (looks like the old flip up sunglasses that attach to the bridge if your glasses) reading lenses that can be ordered in various dioptre powers. Want to look at the lcd flip them down, finished flip them up, then remove them from the glasses when completely done. Second method…these are lenses for glasses that are not bifocal with a line, not progressive lenses with a small reading area, but the top half of the lens on your glasses is your distance Rx and the bottom half (no bifocal line in them) would be for the lcd at about 40cm. The beauty of the lens is that there is very little head movement up and down to go between the distance and near part of the lens. Lenses may go by the name of Access, office, computer lens, etc. Next on the list,….contact lenses for distance and over the counter reading glasses/1/2 eyes for the lcd. Last is surgery, if you have not yet had cataract surgery. The newest implant lenses are designed for clear distance and very clear vision at the distance you normally hold your phone. I know photographers that have each done one of the above. And…Allergan has received approval a few months ago for Vuity eyedrops to assist with close up vision by use of the pinhole effect. We do not yet have enough practical patient data to tell you anything in detail about the success rate and who is the ideal candidate.
VUITY? (pilocarpine HCI ophthalmic solution) 1.25%, the First and Only FDA-Approved Eye Drop to Treat Age-Related Blurry Near Vision (Presbyopia), is Now Available | AbbVie News Center
Hope one of these methods may prove useful for you.
Thanks for the advice, the flip up reading lens is new to me and interesting, but focusing is only part of the reasons I want the EVF I mentioned earlier. The ultra hi res. LCD was just a random thought pops up on my mind and nobody will make that happen ha ! so the hoodman add-on is the best and only practical solution to me.
Another less crazy thought just pops up on my mind, what about a large Fresnel Lens over the LCD, so that the whole screen can be focused via relatively simple and low profile mechanism, but I don't know if that would work, and coarser image and moire are expected no doubt.
Just so happen I got a very fine flexible magnifier sheet plastic in my wallet, I tested and find it does do focus but need quite large working distance, or the 'power' of the sheet is too low, also must close one eye to use it, sort of 'success' to prove my theory ha !
