I have a crazy silly thought but quite do-able.
Due to my farsighted vision I need OVF/EVF to focus, I can't read the LCD clearly at close distance, and stray light will ruin the display, but there are highend digital cameras without EVF built in, I wanted but did not get the MX-1 simply for this reason. I believe if we have a LCD with high enough resolution and a fast enough CPU, we could partition a small section to mimic the EVF at the top left or any place we want, then put a diopter over it that's all ! I know we can put a loupe over the LCD but that would be too large and cumsbersome inconvenient to use. The diopter can simply clip onto the camera as an accessory and the rest will be done by software. In the same sense all DC can have electronics shutter done by s/w although not as good as the real one will work, how that sounds ?
