You could try something like
this quick link or maybe
this one or even
this one (I worry the opening may be too narrow with the last one).
I can't think of a way to test whether it will work other than just ordering one and seeing. I measured my K1, and I think it's possible those would work for you assuming your camera's eyelets are the same. Getting the eyelet 'around the bend' so to speak would be the part I would be worried about (the last one is thinner gauge, so may be better in that respect).
All those parts are also available in stainless with higher capacity ratings, but they're pretty spendy for something that may or may not work out.
If you find one that works, it would obviously be up to you to figure out how to connect a strap to the link, but that part shouldn't be too tough.
Edit:
another possibility, although I worry about the pins backing themselves out with this one, and they may be too thick anyways.
