Originally posted by Paul the Sunman I am confused by the plethora of filters (of one type) of each brand.
For example, if I look for Hoya circular polarising filters on a popular website in Australia, I see many different options, distinguished only by price as far as I can see. For example, for 77mm for example: UX II CPL Au$69; HD Mk II $139; HD Nano Mk II $169. To confuse matters further, when I look on B&H the Hoya models are completely different: HRT US$57; alpha $61; Moose $65; NXT $90; NXT plus $95; EVO antistatic $156; HD3 $199. Other brands also seem to have ranges of offerings.
Why so many? Are the prices really indicative of quality? Why the completely different model names in the US and Australia? Should I just guess that mid-range will be good enough?
Prices are very often an indicator of quality.
Is the filter made of cheap float glass or is it cut from optical blanks and then ground to be plane parallel?
Do the coatings give a colour cast?
Do the coatings inhibit reflections sufficiently?
In the case of polarizing filters, does the polarizing screen give a strong effect at full polarization or a weak one?
Are the rings rolled aluminium that will jam on your camera or are they brass with cut threads that won't?
All of these things will add to the price.
When I bought ny DFA*50/1.4, I went on a quest for good quality filters to put on it. I had just bought one of the best 50mm lenses made, and I wasn't about to trash it's quality with filters that weren't as optically refined as it.
I did quite a bit of research and ended up looking at filters from Carl Zeiss (specifically T*) and also from Breakthrough Photography (specifically X4). They seemed to come out on top of any of the reviews I read.
And yes, they are stupid expensive, but the optical system is only as good as it's weakest link, so putting a filter of dubious quality onto a high quality lens is a great way to waste lots of money on good lenses.
If you are using mid range lenses, probably a mid range filter will be fine, but if you are using top quality glass, don't kill it with a bad filter.
