Originally posted by ProfessorBuzz At work, we use cleanroom stuff from ULINE. They have sticky mats that help get rid of stuff tracked in:
ULINE - Shipping Boxes, Shipping Supplies, Packaging Materials, Packing Supplies
Changing the furnace filter more often does help. Plus as @wadge22 suggested separate entry space. I don't have room for it, and it kind drives me nuts when doing product shots. I have a compressed air setup that I use for cleaning the surfaces, and a microfibre cloth too. I use nylon or cotton gloves as sometimes I'm the source of dust./dry skin/hair when doing macro work.
I've also found a Weller WSA350 smoke absorber fan with carbon filter can get rid of some stuff, or at least pulls dust it's way.
Anybody got other ideas?
Be careful with furnace filters. The temptation, when attempting dust control, is to put a higher MERV rated filter into the return. Depending on what type of furnace you have, you can damage the furnace with too dense a filter.
If you are running a plain jane furnace (mid efficiency or lower) you can pretty much put whatever you like in the slot, but if you are running a high efficiency, a MERV 11 is about as high as you want to go. The reason for this is these furnaces move a lot more air than older ones and the denser filter can cause cavitation between it and the air pump causing the furnace to shut down, and even if it doesn't cause that, it can damage the fan bearings.
A better solution is to get your HVAC ducts cleaned regularly and put a filter on the HVAC inlets to the studio room only. You will lose some air circulation to that room, but you won't be harming your furnace.
To keep dust down, humidity is your friend.
I also saw a youtube video where a guy had built a room dust filter using a 20" box fan and furnace filters attached to it making a 20x20x20 inch box with the fan as one side.
Disclosure: I sell this stuff for a living.
