Originally posted by Digitalis Lens Calibration is dominantly body dependent*, usually I calibrate a lens for a specific camera body and the first thing I calibrate is the infinity focus point - once that is properly set, AF calibrations are checked for accuracy and repeatability. To calibrate AF I use Datacolour Spyder LensCal - I find it produces repeatable and reliable results when used properly. The standard short ruler is fine for lenses around 100mm anything approaching 200mm and over the longer ruler is often needed.
Personally, I've found an alternative lens calibration method that works for all focal lengths from 15mm to 300mm and better reflects the focussing distances I use. I've become suspicious that testing with a ruler inside ie at a short distance can be problematic for some body/lens combinations. So I lay a ladder on boxes. Fix tape, ie hazard tape, which has regular markings on to the ladder. Then vertically set up a focussing target on the ladder about halfway along its length. I then have both the tape's graduations and the ladder's rungs to check the back/forward focussing. The advantage of this setup is I can check te AF accuracy from both near and distance.
I calibrate for every new lens for each body. I then record it in case I lose the camera settings. I've also spot checked occasionally, especially after firmware updates, as settings have sometimes seem to have drifted.
Of course now most of my photography uses manual focussing I do wonder why I bother
