Originally posted by Athanassios I recently compared two shots taken @300mm with both Sigma 18-300 and Pentax 55-300 PLM and, apart from the quality, I was puzzled that Pentax brought the subject some 10-20% closer.
This is probably due to focus breathing rather than "cheating".
A 300mm lens on an APS-C camera has a field of view (FOV) of 5.4°. But a lens is at its narrowest FOV for a particular focal length only when focused at infinity. When focused at a closer point, the FOV will be at least slightly wider. (There might be exceptions amongst non-internal focus lenses, but put that aside for the moment.) The difference is called focus breathing. Lenses with internal focus (IF) - that is, where the front element does not extend during focusing - have more focus-breathing that non-IF lenses. With some lenses the difference is marginal, with others it is great.
The 55-300mm PLM, which has IF, has more focus-breathing than the earlier screw-driven non-IF 55-300. (I did a comparison here:
55-200, 55-200 WR, 55-300, 55-300 PLM, etc, which telezoom I should get? - PentaxForums.com.) But my conclusion was that it didn't make much difference in practice. For close subjects, the shorter minimum focus distance of the PLM largely offset the focus breathing, which was why the two lenses have about the same maximum magnification. By field-relevant focus distances (about 6m in my test), the difference was negligible.
Wide-ranging IF zooms - and superzooms in particular - are notorious for high levels of focus breathing. The Tamron 18-250 and Pentax DA 18-135 are examples amongst lenses I have owned.
Judging by its specs (
Sigma DC Macro HSM (Contemporary) 18-300mm F3.5-6.3 Lens Reviews - Sigma Lenses - Pentax Lens Review Database), I would expect the Sigma 18-300 to have less focus breathing than these lenses. It doesn't have internal focusing and has a maximum magnification of 0.33x (which Sigma dubiously calls "macro") at its MFD. But given its MFD is only 390mm (compared to 900mm for the 55-300PLM), there must be quite a lot of focus breathing close in. At 390mm from the subject, the DFA 100mm macro would have comparable or greater magnification with only one-third the focal length.
If you want to pursue the issue, take a series of images with the two lenses at 300mm at different distances to subject and compare the FOV. Start by comparing subjects at the MFD for each lens (the Sigma should have more magnification), then the MFD for the PLM, then at a few field-relevant distances, then close to infinity. By the time you get close to infinity there should be hardly any difference.
[Edit: @allanmh posted while I was writing this, making the same point.] Originally posted by Athanassios prise wise I feel distressed that in current market, eg ebay, the SIGMA 50-500mm F/4.5-6.3 DG OS HSM is sold 50% CHEAPER on other camera brand mounts.
@StiffLegged has answered this. It's just supply and demand.
It might be worse now that more people are selling off DLSR lenses and shifting to ones designed for mirrorless mounts, but the complaint is not new. For as long as I have been a member here (8 years) people have complained about the dearth of affordable AF lenses of 400mm+ in K-mount. Pentaxians who want lenses that are cheaper or longer than the DFA 150-450 (or DA*300 + TC) pay more because they are chasing fewer lenses.
Tamron and Sigma never released K-mount versions of their xx-600mm zooms, and probably never will, because they calculate that they could not make sufficient profit from them. The only way we are ever likely to get such a lens would be a collaboration, probably with Tamron, like the collaborations that produced the DFA 15-30 and DFA 24-70. But Ricoh might be concerned that such a lens would cannibalise sales of the DFA 150-450.
