Originally posted by UncleVanya That’s the site I’m browsing on actually!
---------- Post added 01-31-23 at 06:21 PM ----------
You are correct. There’s no shock involved to speak of. I have considered using corrugated plastic dividers also. Got a picture of the pegboard idea? How are you suggesting I use it? It sounds like it would be parallel to the drawer bottom held up using pegs and then I’d cut out holes for the equipment?
For cases I don’t love it. The cases need to be reconfigured too often in my experience. But for less changing storage why do you say this?
No pics scanned, no. It's down and dirty drawer mod. Raise the pegboard up a bit then just add the dowel where needed to contain or lift. You can mod dowels with various tape/sel-adhesive products, tubing, pad the ends, play Lincoln log with them by adding dowel to other wood shapes cut to fit. Typ a 1/2" x 1/2" piece is fitted around the perimeter with a few intermediate blocks in center. No additional cutting of pegboard beyond fitting to drawer required.
Pegboard would need finishing and both would need to be allowed to outgas - heat and/or ventilation will accelerate the process. Personally I like shellac as it's main volatile component is alcohol and it goes away quickly. The reason I like silicone is it generally doesn't put out much after curing and distributon process, but if in doub most can be readily cooked in low temp oven say 120* for an hour, and unless your environment exceeds that after, there's little to no measurable gassing. Wood glues not Elmers original or Titebond 1 will outgas formaldehyde for a bit. Again a warm ventilated curing period mitigate most if not all.
