Originally posted by JohnMc Past the operator and design issues, Aperture was dropped for inability to play nice with 64bit SW. Good bad or whatever doesn't really matter, that was what, 8 years ago. We're using a lot of SW now that's potentially susceptible to similar vagaries. That's why you want to keep the orig raw if you ever want to revisit and/or a standard flattened full res file. I'm a bit confused over what you do/don't actually have and what you do need. While you're still young enough, and your favorite devices are still running, I'd figure out how to get them out to a lasting format. That could be accomplished with a reasonably simple scripting solution once you've got the recipe and locations down you can press go and hit the woods, dance floor, or sack, the Retroactive Ap may also be worth looking at depending on you ultimate plans for your catalogue. Odds are the problem/issue won't be getting easier as all parts ages. ;
Personally, I save full size high quality jpegs in another folder reduced size jpegs, in another folder the DNG originals, and in another full size tiffs, most in folder organized year/month/day so I can look them up easily, with a quick look at the exif of the image I want to retrieve. The full size tiffs and jpegs are saved with all the editing changes so I don't lose my edited work. As well I save the Photos libraries, for re-editing if necessary. Like Aperture, if this Photos is no longer supported, I'll keep these computers alive for access. The crappy Aperture to Photos import function which deleted cropped portions of the images so you can't go back and recrop or change your edits is unacceptable. I'm willing to stop upgrading a machine to avoid that trap, currently a 2019- lap top is my Aperture machine.
The only thing I might do different in the future would be a 6T drive to back up the 4T, which is pretty much full to add 2020-2021-and 2022 files that are currently on working drives.
One drive has archival files, there are two working drives that I use for referencing files from the last two years. As well there is a drive that has full size finished tiffs of all images I've posted in the last 2 years, that's permanently plugged into the computer for instant access. My archival drive is plugged into an older computer, that is slow but steady.
My only worry would be fire.I guess I could solve that by putting one of the archival drives over in the Cabin... there's a pretty large parking lot between the house and cabin, so it's unlikely a fire could destroy both.
