If you are here (PF), you probably know this trick. I am not the inventor, but I came up with the idea independently.
Pentax does not make an AF extension tube, nor does anyone else in the Pentax mount.
What to do?
Get an AF rear converter, remove all of the glass VOILA, a Pentax mount AF extension tube!
1.4x = ~ 18mm of extension, 2x = ~ 25mm of extension. I have combined them for ~ 43mm of extension.
The shorter the focal length of the lens, the greater the effect of the extension.
Enjoy.
Jack
