Originally posted by el baroda Hi. I hope I am in the right forum.
Would somebody please advise how the above converter would perform with the Pentax M 135mm f/3.5 lens? I have a dedicated Vivitar 100mm macro lens but I would like to have a longer working distance since I like taking macros of active insects. With the Pentax 135mm lens plus converter, what would be the magnification and working distance?
Thank you very much.
With so many converters out there : ?
Double your magnification , 135mm lens becomes 270mm F3.5 becomes F7 ..
I can barely hold 200mm of macro lens steady , @ 250mm there is so much movement I lose about 50% of shots to blur ... The rest are soft , and maybe 10% can be considered good .
Focus distance could increase as well , this is not a bad thing with so much magnification ...
I run a Tamron 90mm BBAR on a 2x Tele converter ( 180mm + Crop factor ) And I consider that the outer limits for magnification and hand held photography .
Now what sort of converter is it ? Fixed or adjustable ? Matched or for a fixed size ( mm )
Do you have a picture of the converter to share ?
And don't let anyone dissuade you from trying a converter , I use them all the time .. ( Truly wonderful little accessories )
A 50mm lens and 2x Tele Macro converter can be had for $100 or less and will compare to some seriously expensive Macro glass when components are carefully chosen .
