Originally posted by promacjoe Yes, But before you can drive a car you need to know several things, 1: What a car is, 2: What a road is, and the rules of the road for the country that you are driving In. You can't put someone behind the wheel of a car, and tell them where the brake and accelerator is, and then expect them to drive across country, Much less a busy metropolitan area. It is a learning process, and that learning process needs to include the basics First. By the way, I'm a firm believer in anyone who drives a car should know how to check the oil and other fluids, along with being able to change a tire if necessary.
it always bugs me when I picked up a instructional book that says do this this and this but never tells you why. that's how you tell a machine what to do, not people.
and by the way, in my opinion using cheap macro filters is one of the worst ways of doing macro photography. In order from worst to best, Macro filters, bellows, extension tubes, And a dedicated macro lens.
you should teach people to be innovative in the photography, not just do assembly-line photographs. And the only way you can do that is by teaching the basics first so they have a good foundation of what they're doing.
When it comes to CF filters , I hope you are speaking for yourself !
Because as far as I can tell , they work rather well ..
Now Im in no way claiming that they will compete with a Tokina 100mm F2 or any other high quality Macro lens ..
But for $5 or less , they come awfully close , especially considering the budget lens they may be attached to .
And for $5 or less , can give the prospective newcomer one hell of a cheap education .
I have seen way too many ??? ( Bad ? ) macro's taken with expensive glass , to po po any method of Macro where the results speak for themselves .
And not everyone can do , or like doing , Macro , some one else s way . And if you don't like something , are you really going to give it the old College try ?
CF Filters have a learning curve just like any other method of Macro: You either take the time to learn , or you don't .
---------- Post added 12-29-14 at 01:50 PM ----------
Originally posted by marcusBMG Sure, an admirable philosophy. And I think starting with close up filters as being easiest and cheapest is perfectly reasonable. In making my comments I tried to put myself in the mind of a relative novice: what would that person want to know + what does that person need to know.
You mention the exposure apects and my thought is its always relevant to spend a moment touching base with those fundamentals.
i envisage that person going, hey my lens already has macro written on it. So what does/doesn't it do? How does doesn't become does (if that makes sense)?
So I'm kinda a bit more with promacjoe .... but its your project and you have a plan!
It is a 3 part plan :
And as I mentioned I will get there , in Part 3 ..
Once Part 3 is completed , parts 1 to 3 will be combined .. But for now , everyone is just going to have to wait ! Cos part 2 is next .. And in part 2 we will get a little more involved , but with light ( Flash ) .
Its all about an easy transition :
For those with Macro on their lens ..
Well the Kit lens ( Pentax ) is close focus , dont know if Pentax claims Macro , they have in the past ...
The Canon 35-135 says Macro on it , and I didnt want to go there because the CF filters brought the focus distance down to where the results are more Macro like ( well 1:2 Macro )
Again I didn't want to get all techno because it does not matter .. This is all stuff people learn on the way ..
And knowing a bunch of techno stuff does not necessarily make you a good photographer ..
You just need to know the basics , Aperture , shutter speed , and ISO and how they relate to each other .. That's it to start with ... Just go out and take pictures .. Why confuse the issue ?
DOF will come quickly , but that's a relationship between aperture and focus distance ...
Something I touched upon , but wont get into deeply until part 3 .. I will emphasis it some in Part 2 ( DOF )
But I feel many regulars here wont be happy until part 3 is out .
