Originally posted by smf For extreme close-up photography with my K-x, I reversed a 1:3.5/28 Super Takumar on an SMC Pentax M 1:3.5 135mm. The 135's aperture is set between 3.4 and 5.6. The 28 mm is set at f/16 (and previously at a larger aperture.) I chose the M setting and set the shutter at 2 second delay. I am shooting on a focusing rail mounted on a tripod, and I use an LED light to supplement room lighting. Although I can see my subject when using Live View, I am failing to capture an image. When I attempt to view in the LCD the "image" I attempted to capture, I instead see the last image I captured (a snowy landscape) before I mounted the combination of the 135 mm lens and the 28 mm lens.
In other unsuccessful attempts on a previous day, I used other aperture settings and the Auto Pict and AV settings.
I do hear a shutter sound.
I will be grateful for suggestions.
Thanks very much.
Leave the aperture wide open on the stacked lens ( Please )
If your not using a flash (?) start the aperture wide open on the lens in the body .... 28mm to 135mm 4.82:1 That's a lot of Macro , I tried 3:1 and it was small ..
Never mind ..
FOCUS is critical , one mm one way or the other and you might be out of focus .. ( Bare this in mind )
You need light , unfortunately your playing with a M lens ..
So fully manual .. I would try a timed shutter 3 seconds maybe as camera shake will also be critical .. ( Maybe 12 seconds )
Your at such an extreme level of macro , that everything is critical ...
As for shutter speed ? , I would maybe start around 1/10 ...
Whats bad is if its black = No light ...
If your getting light , then its one of several other issues ..
Focus - Seriously critical
Camera shake - Oh boy is it bad at this level
DOF - almost non existent at low F-stop
What I would do :
Stacked lens left wide open
Lens in body , max F-stop what ever it might be
Flash , where is the POF ( point of focus ) how many mm in front of the lens ? You need to get a lot of light here ...
Securely mount the camera ( Tripod ) for minimum camera shake ... Just the mirror lifting could induce too much movement
So I would use the shutter timer - it lifts the mirror right away and then counts down and takes the image without inducing further vibration ..
And after that its trial and error :
If your saying the camera stops capturing an image ?
Pull out the card and see whats on it ..
If its a bunch of black images your simply not getting the light you need ..
