01-08-2015, 07:15 AM   #16
QuoteOriginally posted by old4570 Quote
Hmmmm, Interesting ..
Might need a little more DOF .. And more light ..
A flash would obviously reflect of the surface , what about a small flashlight ?
put the subject on top of a small flashlight , some filters ( Paper? ) to ease of the amount of light ..
Then the glass will be sitting on top a light source that hopefully will show off the inner ... And allow for a smaller aperture for more DOF ..
Lens stacking might be ideal ..
Thank you,
I found a small flashlight and braced it upright and it's just the right size to put the glass on. This seems to be working well. The lightbox had, I think, too much light area. The flashlight has a narrow beam that I can control more easily. Thanks again for the tip.
maria
01-08-2015, 07:45 AM   #17
Not a Number's Avatar
Make a light table - sheet of glass or plexiglass raised up with lighting underneath. A couple of these gooseneck LED lamps from Ikea are very useful for macro work
JANSJÖ LED clamp spotlight - IKEA
There is a model with a desktop foot too.
Definitely play with focus stacking.
01-08-2015, 07:59 AM   #18
MSL
MSL's Avatar
QuoteOriginally posted by mariakruse Quote
Thank you, I found a small flashlight and braced it upright and it's just the right size to put the glass on. This seems to be working well. The lightbox had, I think, too much light area. The flashlight has a narrow beam that I can control more easily. Thanks again for the tip. maria
You could use some construction paper with cutouts on the light box. Should be more stable than the flashlight, and also gives you scope to create light sources smaller or larger than the piece of glass.
01-08-2015, 08:13 AM   #19
Thank you for that link to the spotlight. My lightbox is on a table with a lip that would be good for using something like that.
maria
---------- Post added 01-08-15 at 08:14 AM ----------
QuoteOriginally posted by MSL Quote
Oh, good idea. I shall try that today. Thank you.
maria
---------- Post added 01-08-15 at 08:18 AM ----------
QuoteOriginally posted by GUB Quote
Nice work.
persevere.
When you are at that level of magnification you are caught between the tyrants of diffraction and lack of Depth of field.
(if you stop down too much diffraction kicks in.)
This is a rule of physics and all lens would behave similarly.
Bellows would be my call.
And recognize lots must be out of focus and work that into your image.
---------- Post added 01-09-15 at 12:54 AM ----------
Hang on if she is talking about a DA lens then she is not going to have aperture control on bellows is she ?
Maria you may be better off with an old A or M lens if you need that extra magnification -- they are as cheap as.
Thank you, I forgot about the diffraction completely. I've never used bellows before so I shall have to do some research.
maria
01-08-2015, 01:37 PM   #20
GUB
GUB's Avatar
maria
maria
maria
Yeah I am pretty sure you will be stuck wide open aperture wise with that lens on a bellows. Hoping someone using shiny new stuff like that will confirm.
01-08-2015, 01:48 PM   #21
MSL
MSL's Avatar
Nice work. persevere. When you are at that level of magnification you are caught between the tyrants of diffraction and lack of Depth of field. (if you stop down too much diffraction kicks in.) This is a rule of physics and all lens would behave similarly. Bellows would be my call.
Focus stacking might be one way around this.
I'm hoping I get a chance to try this, as I can finally play with my bellows and maybe my lens reversing rings
01-08-2015, 01:50 PM   #22
If it's the Pentax Auto Bellows K, M, or A you can stop down the aperture or have it wide open. Without an aperture ring on the lens it will only stop down to the smallest f-stop.
On bellows or extension tubes without the auto aperture lever the lens will be stopped down.
01-08-2015, 07:53 PM   #23
old4570's Avatar
No worries
Thank you,
maria
I'm a bit of a flashaholic so it was the first thing to come to mind .
as for DOF , aperture F-stop ...
Try more light , I know to the naked eye it might look like too much , but once you start to close the aperture you should be able to control the amount of light ( too much light = use smaller aperture )
Im going to try this , looks interesting .. But maybe with a emerald or ruby or something ....
Would love to see more pictures :
01-08-2015, 08:11 PM   #24
What a marvelous idea for a subject: the internal cracks, fissures in colored glass chunks. It's so obvious now that you show it, but it took an artist's eye to see the possibilities.
You have several dimensions of choice. The lens is one, lighting another, background a third.
For background, I'd use black velvet.
LENS: For shooting flowers, bugs and fungi I love my 90mm macro lens by itself. You don't get much depth of field with macro shots, but with a longer lens than 30 you sure get more. You can also put good quality achromatic close-up filters on any good zoom lens to make it focus much closer. I prefer that to using extension because you don't lose light as you would with extensions or bellows. Canon makes the 500D and 250D close up filters of excellent quality. Marumi's DHG Achromatic 330 close up is great too. The Raynox DCR 150 and 250 are good too, but small.
Lighting: I like the idea of some light from below via a flash light. You also might try different colored gel filters on the lighting to see what effects you get. I have a Cokin Creative Lighting System that comes with colored filters for each flash, in all colors ala Cokin. It's good as a macro flash just by itself but the colored filters add variables. Many of the LED ring lights come with colored rings to experiment with.
Another toy... err... tool I have been wondering about is a three-armed LED with color filters. Since your subject does not move, you can use the weak light of a LED in long exposures to good effect. I've been looking at this on ebay and tempted, but I know the light output is weak, not a problem for longer exposures.
Last edited by slowhands95128; 01-08-2015 at 08:43 PM. Reason: make Cokin pic larger
01-09-2015, 08:54 AM   #25
Ruby would be fun but I fear I am stuck with beach glass. I did get a couple of large crystal like rocks to play with. Anyway, here are 3 more from my experiments.
The pinkish one is from the crystal rock I was given.
maria
01-09-2015, 09:30 AM   #26
That last one is badly blurred... and the first one just a bit? I may have missed this in the thread, but do you have a remote?
01-09-2015, 10:04 AM   #27
QuoteOriginally posted by Giklab Quote
No remote, I am now using 2 sec delay, but sometimes the image is inside the glass a ways and I can't peel away the stuff on top yet.
Thanks for the reminder about a remote. I will get one.
maria
01-09-2015, 10:13 AM   #28
What body are you using? You may be able to use tethering through PK_Tether or PKTriggerCord. I'm able to use PK_Tether and along with remote triggering I can save the files on to my PC and then look at them on my monitor.
01-09-2015, 10:37 AM   #29
I am using a K3 and experimenting with several lenses and lighting setups. Photo1 was taken on a mirror with light from above. Others lit from below. I have never shot tethered but it sounds like a great idea.
maria
01-09-2015, 03:12 PM   #30
I am using a K3
Unfortunately the K3 is not supported by either program. I suppose you can use the FluCard if you have it and a suitable WiFi device.
couple, couple of weeks, cube, diffraction, filters, glass, ikea, lens, light, luck, macro, magnification, marbles, maria, mirror, pm, post, spotlight, table, time, weeks
Macro Mode on Zoom Lens Classpro Troubleshooting and Beginner Help 5 12-21-2014 08:50 AM
Sigma 70-300mm f/4-5.6 DG Macro Telephoto Zoom Lens for $112 TropicalMonkey Pentax Price Watch 2 06-30-2013 05:49 PM
What is a good zoom lens for reverse lens macro? dmbaile2 Pentax SLR Lens Discussion 5 08-15-2012 11:32 PM
For Sale - Sold: Prime Lenses--Macro Lens--Zoom Lens for Sale (CONUS) stl09 Sold Items 16 01-14-2011 04:53 PM
All times are GMT -7. The time now is 08:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
