01-24-2015, 12:28 PM   #1
csa's Avatar
First macro with Sigma EX DG 105
I know they are horrid, but the light was not favorable, and the operator was not favorable either!
BTW, the spots, etc., is not the lens; rather this poor fly has been stuck on a glass storm door all winter, and you are seeing the dirty glass.
PENTAX K10D  Photo
PENTAX K10D  Photo
01-24-2015, 12:31 PM   #2
Cool shots! I'd highly suggest investing in a ring flash, you will be amazed with the results.
01-24-2015, 12:36 PM   #3
csa
csa's Avatar
Thanks! Yes, I would love one, but I've got to wait now, since I just bought this & a 400 Tokina. I had tried my popup flash on the fly, but it didn't work well at all.
01-24-2015, 12:36 PM   #4
Otis Memorial Pentaxian
photolady95's Avatar
And spot metering and higher f stop will get you more detail. I use the onboard flash with success. But that's a good effort.
On the pop up you either need to diffuse it, or select an ev compensation. I use EV compensation set on either -07 or -03.
01-24-2015, 12:52 PM   #5
csa
csa's Avatar
QuoteOriginally posted by photolady95 Quote
Thanks for the great tips! I really appreciate it. I'll give your suggestions a try! That is the only bug I'll see for a couple of months; I was so hoping it wouldn't fall off the glass before I got my macro!
I'm amazed how small an area is in focus! I wasn't trying to focus on the head/wing, etc., just the whole fly; and I can definitely see how exact the focusing spot is!
01-24-2015, 12:57 PM   #6
QuoteOriginally posted by csa Quote
You're welcome!
This is why we use such smaller apertures, or openings, remember the smaller the number the more light gets in. I've used f8 to f16 to f22 to get more details.
01-24-2015, 01:04 PM   #7
boriscleto's Avatar
If you can't afford a ring flash you could try an older flash gun like the AF280T. It doesn't have P-TTL, but it can be set manually and it depresses to -15 degrees for close up work.
There are also ring flash adapters and led ring lights that won't break the bank.
The Ring Flash Adapter - The Photojojo Store!
01-24-2015, 02:00 PM - 1 Like   #8
In a pinch.
You can use a Pringles can, a rubber band, and a white paper towel to make a macro flash extender for the onboard.
01-24-2015, 02:15 PM   #9
You might also consider buying any sort of cheap flash that will work with your camera and making a KFC ring flash.
01-24-2015, 02:29 PM   #10
csa
csa's Avatar
Lots of great suggestions, thanks all! I'm very excited to get into the world of macro; seeing all the wonderful work that's been posted here, is very inspiring!
01-24-2015, 03:56 PM   #11
csa
csa's Avatar
I was checking out ring flashes, and it seems they come with adapter rings. My filter size is 58mm; so if a ring flash is say, 52mm; wouldn't using it on a 58mm lens cause vignetting?
01-24-2015, 04:28 PM   #12
My ring flash came with a lot of different adapters for nearly all my lens filter sizes. Plus it has different diffusers that clip over the flash itself.
01-24-2015, 04:43 PM   #13
csa
csa's Avatar
Ok, that makes sense! Oh my, you people are getting me addicted quickly!
01-24-2015, 05:02 PM   #14
This is just the beginning. LOL Wait a bit and you'll be buying more than one flash, more than one lens. Macro photography is addictive. But it is so much more fun!!
01-24-2015, 05:39 PM   #15
csa
csa's Avatar
I can see being lead down that winding road of new goodies!
It was very much fun just trying to get the images of the poor old fly; as bad as they are, I was very pleased that I got some parts sharp. Lighting the area as you've suggested, either with aperture, or a ring would definitely improve it. Macro is definitely a challenge, but so worthwhile! Can't wait until I get a "good" image!
sigma ex dg
For Sale - Sold: Sigma 105 EX DG macro, macro extension tubes, 6+ years warranty *Sale Pending* slip Sold Items 2 08-19-2013 07:39 AM
For Sale - Sold: Sigma DG 70 EX macro with circular polarizing filter *last macro I have left * slip Sold Items 2 08-10-2013 05:47 AM
Wanted - Acquired: Tamron 90mm macro / Sigma 105 ex dg macro / Pentax 100mm macro pentakxian Sold Items 6 05-31-2013 09:58 AM
Sigma 105 f2.8 EX DG Macro Fl_Gulfer Pentax SLR Lens Discussion 2 05-09-2009 07:53 PM
All times are GMT -7. The time now is 01:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
