Originally posted by dcshooter The cheapest way for you to get much more magnification right now would be to get a reversing ring for a few bucks on the 'bay and reverse mount the 50 to the front of your zoom, which will take you to 2:1 and beyond.
Is reversing a lens a real thing?!
That just sounds like an incredible easy way to get dust inside your lens...
Originally posted by photolady95 Just so you know, the Pentax 100mm f4 isn't 1:1 it's 1:2. But there others you can get. I have Tamron Adaptall 90mm M f2.8 that is 1:1 and it can be had somewhat cheaply. Of course there are many options for getting started into Macro. I started out using closeup filters, then advanced to using a Raynox DCR adapter.
There is also another thread on this forums about using many different types of lenses, adapter and closeup filters. When I find it, I'll post a link.
https://www.pentaxforums.com/forums/177-macro-photography/262296-macro-any-means-possible.html
Thanks!
I've looked into Raynox adapters incase I get a 55-300mm WR down the road...
Originally posted by TER-OR You've been a huge help in all my posts!
Thanks again!
Going back to an old post now: Would I still be better off with a 55-300mm WR with a Raynox 150 compared to the 100mm F4 Macro with Extension Tubes?
I'm not trying to be a pro Macro shooter or anything, just wanna be able to get some detailed wildlife shots.
I'd probably use the 55-300 more anyways since I already have an 18-135 to cover the 100mm focal length.
And the Raynox 150 could be used with the 50mm 1.7 and extension tubes?
DSLR on a budget is complicated man!
If only I could just buy dedicated lenses for each aspect of shooting, lol.
