Originally posted by VisualDarkness It's the former natural science student that is itching inside, not the photographer
Ok, that makes more sense now :P
Originally posted by vonBaloney No, NOT similar with macro. With discussing macro, magnification is magnification, no crop factors. (As others have been saying.) Macro photography is an area where the people that shoot it and talk about it have been able to do so without crop factor nonsense muddying the waters. Let's keep it that way. "Life-size" or "1:1" is a pretty easy concept to grasp, and it should be obvious it either is or isn't no matter the sensor size that is capturing it.
If I was going to explain to an inexperienced photographer how to doeal with macro and magnification I would rather stick to my simplified view , than go for *exact* science. Let's imagine we have an old film photographer who knows how to do macro on film. he wants to photograph an object let's say 35mm wide - exactly frame wide , for which he needs a lens that offers 1:1 magnification. But when he switched to APS-C digital, he suddenly realises that he needs to back a little , or change the lens, because object now at 1:1 macro lens setting is not fitting the frame - thus in his mind exceeding the 1:1 magnification ( although it is not obviously). This case for me clearly explains that macro magnification is also affected by sensor crop factor - in this case adding to focal length 50% , and so for simply minded photographer , similarly to easy to grasp the idea of equivalent focal lengths between APS-C and 35mm, it applies to macro magnifications.
If lens used had no helicoid and had fixed focusing point, it would not allow to photograph whole object 35mm wide on an APS-C sensor , because of (one saying it ) the sensor is cropping the externals of frame, or (another way saying it ) sensor is adding 50% of magnification making object appears larger in the frame than the photographer used to 35mm film frames , would expect.
Anyway at least this is how I simplify things on the subject
