06-19-2015, 05:46 AM   #16
bluestringer's Avatar
The Pentax-M 100 f4 is a great lens. You can make it 1:1 with a 50mm extension tube. I have used two cheap 2x converters with the glass removed for extension tubes.
06-19-2015, 06:35 AM   #17
hoopsontoast's Avatar
I have had great results with both the Raynox DCR-250 and Sigma AML-2. Notably with the K85 and FA135. Of course, a MF lens will be a big advantage here, and a cheap K-series is a good call as they have very long focus throw and being well built they don't wobble at all.
I like the Raynox as its very flexible as it just fits on the end of the lens (filter thread from 52mm to 67mm IIRC) where as the AML-2 only fits 49mm filters although you can get step up/down adapters. The AML-2 is very well made though, full metal build and very solid feeling (bought to use with my Sigma DP3M)
First three with the Raynox DCR-250.
FA135
With the K85
with the F70-210 (higher magnification of the plant above)
And K85 with the Sigma AML-2
06-22-2015, 09:29 AM   #18
UncleVanya's Avatar
Simply add a short extension tube to the 100 f/4 and it is able to do 1:1; alternately add a Raynox 150 or 250 to increase options.
06-22-2015, 10:05 AM   #19
osv
Tamron Adaptall-2 SP 90mm f/2.5 (52B/52BB) Lens Reviews - Tamron Adaptall Lenses - Pentax Lens Review Database
should be able to do it for $100 or less, and it rocks on 36mp ff, the sharpest glass i've ever put on the a7r... it also works at all distances, not just macro.
downside is that it's not 1:1, and watch out for light haze on the inner elements.
06-22-2015, 12:53 PM   #20
As a stopgap, you could get a set of extension tubes, either M42 or preferably PK as your M42 adaptor can sit on the end. Any lens will focus closer, a standard 50mm only needs an equivalent length of tubes to reach 1:1. Results will be better with primes and could easily be 85% of proper macro quality.
06-22-2015, 01:37 PM   #21
bertwert's Avatar
QuoteOriginally posted by pentasonic49 Quote
If I got a cheap 50mm prime and a 50mm extension tube, that would be a 100mm 1:1 lens?
06-22-2015, 02:16 PM   #22
UncleVanya's Avatar
QuoteOriginally posted by bertwert Quote
No it would be a 50mm 1:1 lens. Same magnification as any lens at 1:1. The difference between a 100mm and 50mm macro at 1:1 is the working distance. The 50mm combo will need to be closer to the subject to get the 1:1 image.
But as stated earlier a 100mm 1:2 lens only needs a short extension (I think 50mm as it turns out) to get from 1:2 to 1:1.
---------- Post added 06-22-15 at 05:18 PM ----------
Another approach that is cheap, light and fun is to get some extension tubes and an enlarging lens.
https://www.pentaxforums.com/forums/177-macro-photography/285041-lightweight-macro.html
This setup cost me very little since I already had acquired the M42 adapter; well under $100 all in.
06-22-2015, 04:40 PM   #23
bertwert's Avatar
Would bellows, opposed to extension tubes, be useful for macro work?\
http://www.amazon.ca/Fotodiox-Macro-Bellows-Pentax-Samsung/dp/B003EDWHYC
06-23-2015, 05:23 AM   #24
old4570's Avatar
Close up filters will get you in the game ...
06-23-2015, 08:11 AM   #25
Not a Number's Avatar
Bellows are the most flexible solution but they are bulky and fragile. While it is possible to shoot hand-held a tripod (and focus-rail) will give you the best results. Maybe not the best equipment to take into the wilderness without an assistant to help you schlep around the gear
06-23-2015, 09:01 AM   #26
bertwert's Avatar
Macro work is more around my land.
06-23-2015, 09:03 AM   #27
UncleVanya's Avatar
I enjoyed using bellows with my film cameras but I have had limited need since I have a dedicated macro lens. I had a cute small simple bellows for my Nikons. I have a much more capable Pentax Bellows but it is so much bigger and more complicated that I find I'm less willing to get it out.
If you go bellows - I suggest the first foray into this area would be served best by a light and cheap one. You can add a focusing rail as you determine if you need it. Additionally a short extension tube is useful to permit it to mount easily without running into the pentaprism overhang. Great deals can be found on M42 versions which work great if your plan is to use reversed lenses or enlarging lenses.
100mm, 50mm, adapter, cheap, ebay, extension, focus, lens, macro, moment, pentax, sigma 50mm f2.8
Cheap manual solution... igabc Flashes, Lighting, and Studio 10 02-23-2015 03:48 AM
For Sale - Sold: Cheap autofocus Sigmas - 28-80mm macro, and 100-300mm Quazimoto Sold Items 7 05-07-2013 05:49 AM
What is a cheap "macro" solution? telly0050 Pentax SLR Lens Discussion 17 01-10-2012 03:21 PM
Cheap Follow Focus Solution magnosantos Video Recording and Processing 5 08-25-2011 01:28 AM
Cheap macro solution? jmbower Photographic Technique 27 08-17-2007 10:38 PM
All times are GMT -7. The time now is 05:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
