Originally posted by photolady95 I do a lot of macro shooting, I have several methods that I use. But my question is, what's the working distance of your achromat setup?
What we know is that the minimal working distance depends on the lens. We also know that an achromat always shortens the distance depending on its strength. There is for sure a formula to compute the effect / distance. But I don't know it.
But I did a quick test with the DA18-135@135mm as follows. I know that this is not an accurate test, but in my opinion it gives a sufficient indication without too much effort.
K5 on macro rail. A target with something written on it. It got sharp at a distance from object surface to the front element of the lens without any filters at ca. 17cm.
I screwed the Marumi 3+ (ca. 1.5cm thick) onto the lens. As expected the writing (target) was now very unsharp (nice bokeh
). So I had to shorten the distance. The writing got sharp at the distance of ca. 10cm to the front of the achromat filter respectively ca. 11.5 cm to the front element of the lens.
Does this answer your question?
