Originally posted by Racer X 69 Here is a shot of another photographer's extreme macro setup.
As you can see, the only limits to what can be achieved are your imagination.
Thanks for the information.
Gosh! I don't call that a macro set up, I call that a macro workshop. Wow!
---------- Post added 05-09-16 at 01:35 PM ----------
Originally posted by bluestringer I always handhold. Using a tripod in the brush where the tiny creatures are just gets in the way and takes too long to setup. May be ok with static objects, but I've never seen a need. A good flash is a must, as I posted before you can even use the onboard. I use a ringflash and it works great. Set everything on manual, it's all you need. This little hopper was only about 2mm in length, getting close is tricky, but it can be done especially on the early morning.
Thanks for the information. I will bear what you said in mind.
The grasshopper is a beauty.
---------- Post added 05-09-16 at 01:45 PM ----------
Originally posted by TER-OR In the field, wading through the plants in full daylight I usually don't need the flash. Shutter speed is important, of course, so I generally use TAv mode in this flow:
Set aperture to a comfortable range. f13 or higher if you have plenty of light.
Set shutter speed to keep ISO in a good range, below 800 is ideal.
Balance those two based on conditions, keeping ISO in range.
Shoot using back-button focus, camera in AF.C mode most of the time. Also trigger is on exposure priority, not focus priority.
Get used to your focus selector switch, whether on the lens or camera (right pinky finger) so you can swap between auto- and manual-focus as required. Many times the camera just can't figure out what it's supposed to focus on, so dropping to manual focus should become second nature.
Recently I've been shooting more with the flash. I bought the little 201 flash when I bought the K3II, and it seems quite good for macro. Not overpowering, but provides enough light outdoors for some great images. Shutter speed is limited to 180 but that hasn't seemed to be a problem yet. I probably need to start flash shooting in Av mode, as a few images have been borderline overexposed and it seems the TAv flow doesn't work as well.
Then it's practice. Lots of practice. Last year my keeper rate was markedly better than previous years. I think I'm getting better at understanding the insects and at my technique. I look forward to seeing how the K3II performs compared with my venerable K5 I've used for the past several years.
Thank you very much for all the information. I have made notes to remind me.
---------- Post added 05-09-16 at 01:46 PM ----------
---------- Post added 05-09-16 at 01:47 PM ----------
Originally posted by T Evergreen
Thanks for the links. I will check the out.
